We use cookies to provide the best possible customer experience across this site, through third party ads and analysis of web data. By continuing you agree to our use of cookies and our overall privacy policy.
Take an ADDITIONAL 20% off already discounted products. Use code FINAL20 at checkout. Shop Now
Eminence Patriot Cannabis Rex – A clean and full 12" American guitar speaker with a hemp cone and monster tone. • Power handling: 50 watts RMS • Impedance: 16 ohms • Frequency range: 70-5,000 Hz • Sensitivity: 102 dB 1W/1m.
Application: 12" Open or Closed Back
Configuration: 1, 2, or 4 x 12"
Coloration: Clean and full, with lots of body and sparkle. Smokey smooth with high-end definition.
Eminence Patriot Cannabis Rex 12" Guitar Speaker 50W 16 Ohm
Nothing says "American Made" like rock 'n roll or blues. And nothing says "Classic" tone like the Patriot Series of guitar amp speakers from Eminence. Made in the U.S.A. for stand-up volume and reliable rockin' clarity. Seven-year manufacturer's warranty.
• can'na bis rex - n. a clean and full 12" American guitar speaker with a hemp cone and monster tone
Specifications: • Power handling: 50 watts RMS • VCdia: 1.75" • Impedance: 16 ohms • Frequency range: 70-5,000 Hz • Sensitivity: 102 dB 1W/1m • Magnet weight: 38 oz. • Dimensions: Overall diameter: 12.02", Cutout diameter: 10.97", Depth: 5.1".
Electric guitars, guitar amplification, and the birth of Rock-n-Roll in the 1950's collectively established a new use for loudspeakers. Speaker choices were limited in those days and amplifier manufacturers had to purchase products that were common to other applications. Usually, this meant a low-power speaker, often with an Alnico magnet, and limited cone and coil travel.
Due to the nature of the speaker's construction, the sound of the guitar and amplifier combination was impacted by the speaker design. Amplified guitar was a bit more aggressive duty than most other speaker applications at the time and the speakers were frequently challenged in terms of their mechanical movement and linearity. Guitarist learned how to control this non-linearity and use the resulting tonal characteristics to their advantage. Speaker break-up became cool and was a desired feature by most guitarists. The great guitar tones we know now are a result of those events.
Although there are a multitude of distinctive guitar speaker tones available today, they can be broken down into two main categories. We have Marshall and Celestion to thank for the distinctively "British tones" that we are so familiar with. Fender, Peavey, and SLM (Crate/Ampeg) worked with speaker companies like Eminence, Oxford, CTS, JBL, and Electro-Voice to establish tones that are distinctively "American".
Eminence is proud to present the Patriot™ and Red Coat™ series of guitar speakers. Incorporating both British and American cone technology into speakers that are manufactured in the USA gives us the ability to provide you with virtually any tone you desire. Be it British or American, clean or dirty, big bass or screaming highs, we have a speaker that will allow you to "Pick Your Sound".
To help you select the right Eminence guitar speaker, check out Eminence's Tone Guide.
