  • Eminence Omega Pro 12-2KW-8 12" Professional Series Speaker 8 Ohm
Eminence SpeakerPart # 290-4300
Model: Omega Pro 12-2KW-8
The Eminence Omega Pro 12-2KW-8 loudspeaker embodies a wealth of trusted expertise cultivated over a remarkable fifty-seven-year span dedicated to loudspeaker design and fabrication. This profound knowledge is encapsulated within every intricately crafted detail of the speaker's construction.
  • Extreme thermal power handling for the toughest applications
  • Weather-resistant cone and dustcap for ease of mind when used outdoors
  • Incredible 2,000 watt program power handling
  • Optimized cone geometry eliminating break-up modes
  • Rugged cast frame for strength and rigidity
Your Price: $229.99
MSRP: $287.49
Save $57.50 (20%)
12 In Stock
We'll send you an email when Eminence Omega Pro 12-2KW-8 12" Professional Series Speaker 8 Ohm is back in stock or available for preorder.
At its core lies a high-power double layer, meticulously engineered to harness and channel audio energy with exceptional precision. The winding of the copper coil, both inside and outside, is a testament to the pursuit of sonic excellence. This dual-layer configuration amplifies the speaker's capacity to handle substantial power loads while preserving utmost clarity in sound reproduction.
The coil is wound on a robust fiberglass former, chosen for its exceptional rigidity and resonance-dampening properties. This carefully selected material serves as an ideal foundation, ensuring that vibrations are effectively controlled and transformed into pristine, unadulterated soundwaves. Incorporating an acute understanding of real-world conditions, the Eminence Omega Pro 12-2KW-8 has undergone meticulous weatherproofing treatments. These treatments shield the speaker against the elements, allowing it to perform optimally even in challenging outdoor environments. Rain or shine, the loudspeaker remains a steadfast purveyor of impeccable sound quality. Each component within this exemplary woofer is the outcome of rigorous optimization, a result of the amalgamation of decades of experience and cutting-edge engineering. The speaker is not merely a product but a culmination of a lifelong commitment to perfecting the art of sound reproduction.
Bid farewell to the cumbersome chore of hauling supplementary subwoofers around due to space constraints for your main speakers. The Omega Pro 12-2KW-8 offers an ingenious solution by effortlessly delving into the lower frequencies within compact vented enclosures. Bolstered by an impressive 4,000W (peak) AES power handling capacity, these speakers guarantee not only depth but also volume in your audio experience.
The meticulously curated parameters of the Omega Pro 12-2KW-8 are meticulously tuned to excel as standalone units within the confines of modern compact speaker tops. Eminence takes customization to a whole new level, tailoring the frequency responses for a seamless integration into both passive and active network designs. The result is an unparalleled ease in achieving the optimal sonic balance. Eminence's dedicated engineers have invested their expertise and passion to ensure that these drivers will faithfully serve your audio needs for many years to come.
Eminence's Omega Pro 12-2KW-8 loudspeaker is a harmonious symphony of craftsmanship, technology, and unwavering dedication. It is a resounding testament to the enduring pursuit of sonic perfection, a treasure trove of sonic bliss that only half a century of expertise can bestow.
BrandEminence Speaker
ModelOmega Pro 12-2KW-8
Part Number290-4300
UPC876358004706
Weight23.45
Nominal Diameter12"
Bolt Circle Diameter11.7
Frequency Response42 to 1,600Hz
Sensitivity93.33dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)48.14Hz
DC Resistance (Re)6.04Ω
Voice Coil Inductance (Le)1.13mH
Mechanical Q (Qms)14.88
Electromagnetic Q (Qes)0.4
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)1.75ft³
Mechanical Compliance of Suspension (Cms)0.12mm/N
BL Product (BL)20.4T·m
Diaphragm Mass Inc. Airload (Mms)91.96g
Maximum Linear Excursion (Xmax)7.1mm
Surface Area of Cone (Sd)545.4cm²
Surround MaterialPaper
Voice Coil FormerFiberglass
Overall Outside Diameter12.38"
Baffle Cutout Diameter11.06"
Depth6.04"
Sealed Volume0.426ft³
Sealed F3105.2Hz
Vented Volume1.224ft³
Vented F356.41Hz
