  • Eminence Karnivore by Kristian Kohle 12" Guitar Speaker 8 Ohm
NEW Eminence Karnivore by Kristian Kohle 12" Guitar Speaker 8 Ohm
Eminence SpeakerPart # 290-5666
Model: Karnivore
The Eminence Karnivore is a 12" guitar speaker developed with German metal producer and creator of the YouTube channel Kohle Audio Kult, Kristian Kohle. The Karnivore was designed for high-gain players who want a tight, punishing low end, a thick vocal midrange, and an extended top end that cuts through dense mixes without turning brittle. Eminence and Kohle worked together to make a modern metal-focused design that is equally suited to crushing rhythm work, articulate down-tuned riffs, and singing lead tones that stay present at high gain.
  • Tight punishing low end keeps heavy rhythm tones forceful and controlled
  • Thick vocal midrange helps riffs and leads stay present in dense mixes
  • Extended top end adds cut and definition without turning brittle
  • British-voiced attitude paired with American-made craftsmanship gives it a distinct modern voice
  • Built for high-gain players who need power and precision for modern metal tones
  • 60W power handling supports everything from aggressive rhythm stacks to lead-focused setups
  • Developed with Kristian Kohle for modern metal tones that need both crushing impact and clear articulation
NEW $164.99
We'll send you an email when Eminence Karnivore by Kristian Kohle 12" Guitar Speaker 8 Ohm is back in stock or available for preorder.
The Eminence Karnivore is a 12" ceramic-magnet guitar speaker created specifically for high-gain players who want a tight, crushing low end, a thick and vocal midrange, and an extended top end that cuts through dense mixes without becoming brittle. Developed in collaboration with acclaimed metal producer Kristian Kohle, the Karnivore combines British-inspired voicing with American-made craftsmanship from Eminence, Kentucky, resulting in a tone that feels just as ready for the studio as it does for the stage.
  • Nominal Basket Diameter: 304.8 mm (12 in)
  • Nominal Impedance: 8Ω
  • Power Rating Watts: 60W
  • Power Rating Music Program: 60W
  • Resonance 76.82 Hz
  • Usable Frequency Range: 70Hz - 5.2kHz
  • Sensitivity: 98.6 dB
  • Magnet Weight: 1275.705 g (45 oz)
  • Gap Height: 7.95 mm (0.313 in)
  • Nominal Voice Coil Diameter: 44.45 mm (1.75 in)
  • Overall Diameter: 310.90 mm (12.24 in)
  • Baffle Hole Diameter: 281.69 mm (11.09 in)
  • Front Gasket: Yes
  • Rear Gasket: No
  • Mounting Holes Diameter: 3.302 mm (0.13 in)
  • Mounting Holes B.C.D.: 296.93 mm (11.69 in)
  • Magnet Diameter: 155.58 mm (6.125 in)
  • Depth: 130.175 mm (5.125 in)
  • Net Weight: 4.58 kg (10.10 lbs)
  • Volume Displaced: 2.20 liters (134.24 in³)
BrandEminence Speaker
ModelKarnivore
Part Number290-5666
UPC876358008698
Weight11.7
Nominal Diameter12"
Power Handling (RMS)60 Watts
