CLEARANCE Eminence Designer Speaker Box Design Software
We'll send you an email when Eminence Designer Speaker Box Design Software is back in stock or available for preorder.
Eminence Designer is a state-of-the-art speaker enclosure design program for PCs running Windows 95, 98, NT4 or later. With Eminence Designer, box design is as easy at 1-2-3: 1. Enter the speaker parameters (for Eminence speakers, simply select the model; other speaker parameters can be entered manually). 2. Calculate the box volume and tuning. This is very easy with the help of the "Suggest" box. 3. Evaluate the performance with any of the nine graphs. It can take many hours solving complex equations manually with a calculator to design a box that will bring out the best bass response from a speaker. Eminence Designer can do this for you in seconds - it can even suggest a box for your speaker. Eminence Designer models closed, vented, bandpass and passive radiator boxes. It will print box drawings and graphs for a professional presentation. Eminence Designer is quick to learn and easy to use. When the program is first run, a "Welcome" window will appear to help you configure the program and to guide you through its illustrated online manual. System Requirements: Microsoft Windows 95, 98, NT4 or later and a compatible computer (IBM PC with a Pentium processor or equivalent) with at least 16 MB of RAM (32 MB recommended), 17-23 MB of free hard disk space and a CD-R compatible CD-ROM or DVD drive. The Arial and Symbol TrueType fonts must be installed (both fonts are a standard part of Windows).
Product Details | |
Brand | Eminence Speaker |
Model | Designer |
Part Number | 500-945 |
UPC | 876358001248 |
Unit of Measure | Each |
Weight | 1 |
