  • Dolphin DC-100S Super B Crimp Connector with Sealant 100 Pcs.
Dolphin ComponentsPart # 095-354
Model: DC-100S
Dolphin Super B connectors are some of the best wire crimps in the low voltage world. They offer unparalleled connections without having to strip the wires.
  • Save time and money
  • Solid, dependable connections every time
  • No need to strip wires
  • Easy "Funnel-entry" design
  • Available with a sealant for out door use
  • UL Listed: E172979
Your Price: $9.98
Save $8.01 (45%)
51 In Stock
We'll send you an email when Dolphin DC-100S Super B Crimp Connector with Sealant 100 Pcs. is back in stock or available for preorder.
Order in the next 1 hr 42 min to ship today. Details
Dolphin Super B connectors are some of the best wire crimps in the low voltage world. They offer unparalleled connections without having to strip the wires. A unique wide "funnel-entry" provides easy wire insertion when using multiple wires, and helps eliminate wire hang-up. A series of razor sharp teeth deliver a secure contact and pierce through the wire jack, eliminating the need to pre strip your wires. The Super B connectors are available in two "flavors": a plain crimp, perfect for indoor use (white); and a sealant filled crimp, ideal for high moisture location or out doors (blue). The special formulated sealant provides a non-curing, moisture barrier that will not corrode, or flow out of the connector. Available in 100 or 1000 packs. Wire capacity: 4 #24 AWG (Insulated wires) 4 #22 AWG (Insulated wires) 3 #20 AWG (Insulated wires) 3 #18 AWG (Insulated wires) 3 #16 AWG (Stripped wires). UL Listed: E172979.
BrandDolphin Components
ModelDC-100S
Part Number095-354
UPC710983701190
Unit of MeasurePackages
Weight0.2001
Connector TypeClosed End
Terminal / Stud SizeN/A
Wire Gauge24-16 AWG
