  • Dayton Audio Wireless Package for Classic Collection CS1200 Powered Subwoofer Wood
Dayton AudioPart # 300-2058
Pairing the Dayton Audio Wave-Link wireless audio system with the Dayton Audio Classic Collection powered subwoofers makes it easy to add deep, room-filling bass without running long signal cables. Wave-Link delivers clean, low-latency wireless audio from your source or amplifier directly to the subwoofer, allowing flexible subwoofer placement for smoother low-frequency response and better room integration. The result is tighter, more impactful bass for music, movies, and gaming, while keeping your system setup simple, clean, and clutter-free.
  • Wirelessly connect your system to the Dayton Audio powered subwoofer using the Dayton Audio Wave-Link
  • Eliminates long signal cables for a cleaner, easier system setup
  • Low-latency wireless transmission maintains tight, accurate bass performance
  • Flexible subwoofer placement helps achieve smoother in-room bass response
  • Improves overall system impact for music, movies, and gaming
  • Simple integration with existing audio systems and powered subwoofers
  • Clean, clutter-free installation without sacrificing sound quality
Your Price: $329.98
MSRP: $405.97
Save $75.99 (19%)
The Dayton Audio CS1200 12" powered subwoofer system is the perfect addition to any home theater. This powered sub features a 200W amplifier, rear-firing bass reflex design for reduced port noise and increased bass response. It also utilizes a long-throw 8" woofer for house-shaking power. Combine with the Dayton Audio Wave-Link system and you have a totally wireless subwoofer solution.
The Dayton Audio Wave-Link Wireless Audio System solves wiring dilemmas, quickly and easily. Place the subwoofer in the location that provides optimal sound without worrying about a cable. Stream wireless audio from the transmitter to the included receiver.
Dayton Audio CS1200 Specifications
Power output: 200 watts RMS • Frequency response: 26-200 Hz • Box design: Ported • Inputs: RCA line level, LFE & speaker level • Outputs: Speaker level • Crossover frequency control: Continuously variable from 40 Hz to 160 Hz @ 12 dB/octave • Phase switch • Auto on/off • Dimensions: 16.37" H x 15.5" W x 18" D.
Dayton Audio Wave-Link Specifications
• Operating voltage: 5V DC, 500 mA • RF frequency band: 2.403 GHz to 2.479 GHz • Modulation: GFSK • Working distance: 20 meters (66 feet; unobstructed line-of-sight) • Frequency response: 20 Hz to 22,000 Hz • Audio sample rate: 48 kHz • Latency: 32 ms • Audio input (transmitter): 3.5 mm analog and USB digital • Audio output (receiver): 3.5 mm analog • Dimensions: 6" L x 1-1/2" W x 3/4" H.
Part Number300-2058
UPC848791012112
Weight0.95
