Dayton Audio WB65 Pre-Construction Bracket Pair
Use this pre-construction bracket when installing the Dayton Audio CW65W in-wall speakers. Mount your CW65W in-wall speakers in a vertical position between studs, or mount horizontally by add blocking between the studs. This bracket will also work with any rectangular in-wall speaker that requires a cutout of 7-3/16"W x 10-11/16"H.
- Solid ABS pre-construction bracket
- Custom made to hold the Dayton Audio CW65W securely in your wall
- Fits between studs 12-1/2" - 25" apart
- Mount horizontally or vertically
- Adjustable polystyrene straps for perfect speaker placement
- Sold in Pairs
- This bracket will also work with any rectangular in-wall speaker that requires a cutout of 7-3/16"W x 10-11/16"H.
We'll send you an email when Dayton Audio WB65 Pre-Construction Bracket Pair is back in stock or available for preorder.
