  • Dayton Audio TT-HS1 Universal Angled Headshell for 4-Pin Cartridges Black
NEW Dayton Audio TT-HS1 Universal Angled Headshell for 4-Pin Cartridges Black
Dayton AudioPart # 300-367
Model: TT-HS1-Black
The Dayton Audio TT-HS1 Universal Angled Headshell is a high-quality upgrade or replacement solution for turntables with standard S-shaped tonearms and SME-style bayonet mounts. Designed to deliver precision alignment and secure cartridge mounting, the TT-HS1 is compatible with all 4-pin phono cartridges and features a sleek black anodized aluminum body that adds both performance and aesthetic appeal. Whether you're replacing a worn-out headshell or building a custom vinyl setup, the TT-HS1 ensures optimal stylus alignment for accurate tracking and faithful audio reproduction.
  • Universal fit for S-shaped tonearms using standard SME bayonet connection
  • Angled design ensures proper cartridge offset for accurate tracking geometry
  • Lightweight anodized aluminum body minimizes resonance and maintains stability
  • Zinc-plated 4-pin connectors for secure, low-resistance signal transfer
  • A suitable replacement for brands like Pioneer, Audio-Technica, Technics, Denon, and more!
  • Four connection wires included for easy hookup
NEW $12.49
MSRP: $16.99
Save $4.50 (26%)
We'll send you an email when Dayton Audio TT-HS1 Universal Angled Headshell for 4-Pin Cartridges Black is back in stock or available for preorder.
Dayton Audio TT-HS1 Universal Angled Headshell for 4-pin Cartridges Black
The Dayton Audio TT-HS1 Universal Angled Headshell is a high-quality upgrade or replacement solution for your Dayton Audio TT-1BT turntable, or any turntable with standard S-shaped tonearms and SME-style bayonet mounts. Designed to deliver precision alignment and secure cartridge mounting, the TT-HS1 is compatible with all 4-pin phono cartridges and features a sleek black anodized aluminum body that adds both performance and aesthetic appeal.
Engineered for audio clarity, the TT-HS1 maintains excellent contact between your cartridge and tonearm, thanks to its sturdy locking mechanism and precision-stamped construction. The angled design allows for correct stylus alignment, reducing tracking distortion and enhancing stereo imaging across your records.
The TT-HS1 supports virtually any half-inch mount cartridge with standard 4-pin connections, from entry-level MM cartridges to audiophile-grade MC units. Used on our popular Dayton Audio TT-1BT turntables, it's SME-style mount is also a drop-in fit for most turntables from other brands like Technics, Audio-Technica, Denon, and Pioneer.
  • Material: Aluminum
  • Weight (with wires): 9.8 g
  • Dimensions: 14mm (0.6") H x 21mm (0.8") W x 65mm (2.55") D
  • Included: Headshell, four wire leads
ModelTT-HS1-Black
Part Number300-367
UPC848791011290
