  • Dayton Audio RS125P-4 5" Reference Paper Woofer 4 Ohm
Dayton AudioPart # 295-371
Model: RS125P-4
Dayton Audio Reference Series paper cone drivers combine class-leading low distortion performance with super smooth frequency response due to the use of a proprietary cone blend.
  • Three-part paper composite diaphragm featuring paper, Kevlar, and glass fibers
  • Similar cosmetics and design features as original Reference Series with low-distortion motor, 6-hole cast frame, rubber surround, and solid aluminum phase plug
  • Perfect for use as a woofer, midwoofer, or dedicated midrange driver
Your Price: $48.98
Save $15.01 (23%)
We'll send you an email when Dayton Audio RS125P-4 5" Reference Paper Woofer 4 Ohm is back in stock or available for preorder.
Order in the next 3 hr 23 min to ship today. Details
The performance of the original groundbreaking Reference Series from Dayton Audio, now available with a paper cone! The Reference Series Paper drivers use a proprietary paper cone formulation combining natural paper pulp and synthetic Kevlar® and glass fibers to create an advanced non-woven fiber composite that delivers the perfect combination of excellent detail and smooth, natural sonic character, plus a distinctive, classy look.
ModelRS125P-4
Part Number295-371
UPC848791001420
Weight1.85
Nominal Diameter5"
Bolt Circle Diameter4.43
Power Handling (RMS)30 Watts
Power Handling (MAX)45 Watts
Frequency Response70 to 12,000Hz
Sensitivity90dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)70Hz
DC Resistance (Re)3.1Ω
Voice Coil Inductance (Le)0.32mH
Mechanical Q (Qms)3.19
Electromagnetic Q (Qes)0.57
Total Q (Qts)0.48
Compliance Equivalent Volume (Vas)0.14ft³
Mechanical Compliance of Suspension (Cms)1.02mm/N
BL Product (BL)3.49T·m
Diaphragm Mass Inc. Airload (Mms)5.1g
Surface Area of Cone (Sd)54.11cm²
Cone MaterialPaper / Kevlar
Voice Coil FormerAluminum
Overall Outside Diameter4.94"
Baffle Cutout Diameter3.70"
Depth2.16"
# Mounting Holes6
Sealed Volume0.1ft³
Sealed F3134Hz
Vented Volume0.26ft³
Vented F352Hz
