  • Dayton Audio RKIT-ME625W Speaker Rough-In Kit for Dayton Audio ME625W Pair
CLEARANCE Dayton Audio RKIT-ME625W Speaker Rough-In Kit for Dayton Audio ME625W Pair
Dayton AudioPart # 300-446
Model: RKIT-ME625W
Use this pre-construction bracket when installing the Dayton Audio ME625W in-wall speakers. Mount your ME625W in a vertical position between studs, or mount horizontally by add blocking between the studs.
  • Solid ABS pre-construction bracket
  • Custom made to hold the Dayton Audio ME625W securely in your wall
  • Fits between studs 12-1/2" - 25" apart
  • Mount horizontally or vertically
  • Adjustable polystyrene straps for perfect speaker placement
Dayton Audio WB65 Pre-Construction Bracket Pair
Price: $15.00Part # 300-013
See all items in Rough-in Kits, Brackets & Grills
We'll send you an email when Dayton Audio RKIT-ME625W Speaker Rough-In Kit for Dayton Audio ME625W Pair is back in stock or available for preorder.
Use this pre-construction bracket when installing the Dayton Audio ME625W in-wall speakers. Mount your ME625W in a vertical position between studs, or mount horizontally by add blocking between the studs. The strong polystyrene straps are adjustable, so you know the position of your speaker will be perfect. For horizontal mounting, re-lace the straps in the additional slots. Made from ABS, this bracket works perfectly with studs spanning 12-1/2" and up to 25".
Use the speaker clamps built-in to the ME625W to attach the bracket, it's just that easy. This affordable time saver is a must have when installing the Dayton Audio ME625W into new construction, whether that be an entirely new house, business, or your home theater project.
ModelRKIT-ME625W
Part Number300-446
UPC848791001819
Unit of MeasurePairs
Weight1.3
