  • Dayton Audio Bluetooth Powered Outdoor Subwoofer with Stereo Speaker Outputs IOSUBP – Black
NEW Dayton Audio Bluetooth Powered Outdoor Subwoofer with Stereo Speaker Outputs IOSUBP – Black
Dayton AudioPart # 310-042
Model: IOSUBP
The Dayton Audio IOSUBP makes it easy to add deep, high-quality bass to your outdoor setup. Built for performance and convenience, this IP66-rated subwoofer features a built-in Bluetooth amplifier—not just for itself, but also for powering two additional outdoor speakers. That means no extra amps, no complicated wiring, and no need to drill into your walls. With simple volume and crossover controls, fine-tuning your sound takes just minutes. The high-excursion 10" woofer, loaded in an acoustic suspension enclosure, delivers powerful low-end punch in a compact, weather-resistant housing. Ideal for patios, pool areas, gardens, or any landscaped space, the IOSUBP brings full-range, wireless sound to the outdoors—without the hassle or the high price tag.
  • Built-in 160 Watt Bluetooth amplifier powers the subwoofer and two additional outdoor speakers—no external amp needed
  • Weatherproof IP66-rated design is built to withstand rain, dust, and outdoor conditions
  • 10" high-excursion woofer delivers deep, powerful bass in a compact enclosure
  • Custom acoustic tuning provides rich, balanced low-end performance
  • Full-range powered outputs eliminate the need for extra wiring or wall drilling
  • Easy sound control with accessible volume and crossover adjustment knobs
  • Ideal for outdoor spaces like patios, pools, gardens, and backyard setups
NEW $299.98
Save $176.01 (37%)
We'll send you an email when Dayton Audio Bluetooth Powered Outdoor Subwoofer with Stereo Speaker Outputs IOSUBP – Black is back in stock or available for preorder.
The Dayton Audio IOSUBP makes it easy to add deep, high-quality bass to your outdoor setup. Built for performance and convenience, this IP66-rated subwoofer features a built-in Bluetooth amplifier—not just for itself, but also for powering two additional outdoor speakers. That means no extra amps, no complicated wiring, and no need to drill into your walls. With simple volume and crossover controls, fine-tuning your sound takes just minutes. The high-excursion 10" woofer, paired with Dayton’s custom acoustic tuning, delivers powerful low-end punch in a compact, weather-resistant housing. Ideal for patios, pool areas, gardens, or any landscaped space, the IOSUBP brings full-range, wireless sound to the outdoors—without the hassle or the high price tag.
Built-In Bluetooth - Effortless Setup
Effortless setup in minutes! Simply connect the powered subwoofer’s power cable to a nearby power outlet and use the supplied waterproof wire nuts to connect the stereo output to your favorite pair of patio speakers. You can fine-tune the crossover frequency for a smooth blend between the subwoofer and your speakers, then set the subwoofer volume to match the overall system balance. A convenient pairing button lets you easily enter Bluetooth pairing mode or disconnect a connected device with a single press.
The IOSUBP is equipped with a built-in 2.1-channel amplifier and Bluetooth 5.3, eliminating the need to run wires through walls or ceilings—making installation fast, clean, and hassle-free. And because it’s designed for open-air use, the lack of walls or physical boundaries becomes a major advantage: Bluetooth range and stability are maximized, delivering strong, uninterrupted wireless audio performance up to 30 feet from the main speaker.
Built To Survive The Elements
The IOSUBP’s woofer is built for serious performance, featuring a graphite poly cone, 2" 4-layer voice coil, stitched rubber surround and over 10mm of excursion for powerful low-end response. Housed in a heavy-duty down-firing sealed enclosure, it delivers deep, tight bass down to 40 Hz with 160 watts of built-in power. Despite its compact footprint, the subwoofer packs a punch, providing rich bass while blending seamlessly into any outdoor setting.
Engineered to endure the elements, the IOSUBP features an IP66-rated enclosure that shields the subwoofer and internal electronics from harsh environmental conditions, ensuring long-lasting, reliable performance. Its down-firing design offers natural protection for the woofer and controls while delivering omni-directional sound, making placement more flexible and less critical. With its rugged construction and weather-resistant build, the IOSUBP is ideal for enhancing outdoor spaces like pools, patios, gardens, and landscaped areas with deep, immersive bass.
Keeping it Simple
The IOSUBP makes setup and tuning effortless, with dedicated volume and crossover controls that adjust only the subwoofer output, leaving the connected stereo speakers unaffected. You can fine-tune the crossover frequency for a smooth blend between the subwoofer and your speakers, then set the subwoofer volume to match the overall system balance. A convenient pairing button lets you easily enter Bluetooth pairing mode or disconnect a connected device with a single press.
Affordable, Flexible Performance
Adding a 2.1 channel stereo system to your outdoor space doesn’t have to be complicated or costly—Dayton Audio’s IOSUBP delivers exceptional performance, flexible connectivity, and rich, immersive sound at a price that outshines the competition. With its combination of powerful bass, user-friendly features, and unbeatable value, the IOSUBP stands alone in its class. Bring deep, ground-shaking audio to your outdoor area—you won’t regret it, though your neighbors just might.
  • Description: 10" Indoor/Outdoor Bluetooth 2.1 Channel Powered Subwoofer
  • Woofer: 10" Polypropylene Cone
  • Frequency response: 40-300 Hz
  • Low pass filter: Variable
  • Ingress protection rating: IP66
  • Color: Black
  • Dimensions: 12.2" x 16.5" x 16.5"
ModelIOSUBP
Part Number310-042
UPC848864079288
Weight28.66
ColorBlack
ConfigurationSubwoofer
Mounting StyleLandscape
Woofer Diameter10"
Special FeaturesBluetooth
