  • IP68 Outdoor Waterproof Junction Box Wire Splice Cable Connectors 5 Pack 2-conductor M16
Parts ExpressPart # 095-935
These waterproof connectors are a great way to terminate low voltage wiring outdoors. Use them to securely and confidently terminate wiring for outdoor sound system or lighting and get years of worry-free service. Simply terminate either end to the watertight terminals with a small Phillips screwdriver, screw on the end caps, and you are done.
  • Outdoor Waterproof Connector: 2-conductor M16 plug with rubber gaskets prevent moisture from ruining your electrical connections
  • Easy-to-Use: Terminate each end of your wire for a moisture-free connection
  • Versatile: Use these connectors when installing outdoor lighting or audio systems
Your Price: $14.98
Save $8.01 (35%)
We'll send you an email when IP68 Outdoor Waterproof Junction Box Wire Splice Cable Connectors 5 Pack 2-conductor M16 is back in stock or available for preorder.
Reliable Waterproof Protection for Every Connection
Whether you’re installing outdoor lighting, hooking up outdoor speakers, or wiring a security system, this IP68-rated waterproof junction box connector ensures your electrical connections stay safe and dry in any weather. Built to withstand dust, rain, and even submersion, it’s the ideal choice for any project exposed to the elements. Say goodbye to corrosion, shorts, and water damage—this connector has you covered, literally.
Effortless Installation with Versatile Compatibility
Designed for ease and flexibility, this 2-pin electrical connector supports cables ranging from 3mm to 7mm in diameter. Its intuitive screw-lock system makes setup quick and secure, with no special tools required. Whether you're a professional electrician or a weekend DIYer, you'll appreciate how seamlessly this connector integrates into your wiring jobs—both above and below ground.
Built to Last with Industrial-Grade Durability
Crafted from high-quality nylon plastic and an impact-resistant construction, this junction box connector is engineered for long-term performance. It’s not just waterproof—it’s tough enough to handle the demands of rugged outdoor use. From landscape lighting to outdoor signage and more, it offers the reliable power connection you need, year after year.
Specifications: Conductors: 2, Dimensions: 0.8” dia x 2.85”, Certification: IP68, Temperature range: -40 F – 221 F₁ Construction: Flame retardant Nylon, Surround material: Silicone, Rated voltage: 400V, Rated current: 25A.
Part Number095-935
UPC848864079974
Unit of MeasureSets
Weight0.1
Connector TypeButt Splice
Terminal / Stud SizeN/A
