  • Dayton Audio Powered Outdoor Subwoofer and 6-1/2" Indoor /Outdoor IO655WT Speaker Bundle White
Dayton AudioPart # 310-1514
The Dayton Audio IO655 and IOSUBP bundle combines premium indoor/outdoor speakers with powerful wireless bass for a complete, easy-to-install sound system. The IO655 speakers are designed for clear, balanced audio with weatherproof durability, offering excellent sound quality and value whether mounted on a patio, deck, or in a commercial space. Pairing seamlessly with them, the IOSUBP powered subwoofer adds deep, impactful low-end performance through a high-excursion 10" woofer and features a built-in Bluetooth amplifier capable of powering both the sub and two additional speakers. That means no extra amps, complicated wiring, or wall drilling—just simple volume and crossover controls for quick, customizable setup. Together, these components deliver full-range, weather-ready sound that’s ideal for patios, pool areas, gardens, or any outdoor environment, blending rich audio performance with easy DIY installation.
  • Built-in 160 Watt Bluetooth amplifier powers the subwoofer and two additional outdoor speakers—no external amp needed
  • Weatherproof IP66-rated design is built to withstand rain, dust, and outdoor conditions
  • 10" high-excursion woofer delivers deep, powerful bass in a compact enclosure
  • Stylish Finish: Sleek white enclosure suits any aesthetic, from modern to classic.
  • Ideal for outdoor spaces like patios, pools, gardens, and backyard setups
  • High excursion 6-1/2" polypropylene woofer and 1" silk dome tweeter provide a smooth, natural listening experience
Your Price: $423.98
Save $213.01 (33%)
Out of Stock
Estimated back in stock 2/7/2027
Dayton Audio Powered Outdoor Subwoofer and 6-1/2" Indoor /Outdoor Surface Mount Speaker Bundle White
Create a complete, weather-ready outdoor sound system with the Dayton Audio IO655WT and IOSUBP bundle, combining clear, balanced audio with deep, powerful bass in one easy-to-set-up package. IO655WT speakers feature a 2-way design with a 6-1/2" woofer and 1" tweeter, delivering crisp highs and smooth mids, all housed in sleek, IP66-rated weather-resistant ABS enclosures that work equally well indoors or out. Pairing perfectly with them, the IOSUBP subwoofer adds rich low-end punch through a high-excursion 10" woofer and features a built-in Bluetooth amplifier that powers both the sub and two additional speakers, eliminating the need for external amps or complex wiring. Simple volume and crossover controls make fine-tuning your sound quick and hassle-free, while the rugged, compact design ensures durability in patios, pools, gardens, or any outdoor living area.
Effortless Setup
Effortless setup in minutes! Simply connect the powered subwoofer’s power cable to a nearby power outlet and use the supplied waterproof wire nuts to connect the stereo output to your favorite pair of patio speakers. You can fine-tune the crossover frequency for a smooth blend between the subwoofer and your speakers, then set the subwoofer volume to match the overall system balance. A convenient pairing button lets you easily enter Bluetooth pairing mode or disconnect a connected device with a single press.
The IOSUBP is equipped with a built-in 2.1-channel amplifier and Bluetooth 5.3, eliminating the need to run wires through walls or ceilings—making installation fast, clean, and hassle-free. And because it’s designed for open-air use, the lack of walls or physical boundaries becomes a major advantage: Bluetooth range and stability are maximized, delivering strong, uninterrupted wireless audio performance up to 30 feet from the main speaker.
Bass Radiator for Extended Bass Response
The IOSUBP’s woofer is built for serious performance, featuring a graphite poly cone, 2" 4-layer voice coil, stitched rubber surround and over 10mm of excursion for powerful low-end response. Housed in a heavy-duty down-firing sealed enclosure, it delivers deep, tight bass down to 40 Hz with 160 watts of built-in power. Despite its compact footprint, the subwoofer packs a punch, providing rich bass while blending seamlessly into any outdoor setting.
Engineered to endure the elements, the IOSUBP features an IP66-rated enclosure that shields the subwoofer and internal electronics from harsh environmental conditions, ensuring long-lasting, reliable performance. Its down-firing design offers natural protection for the woofer and controls while delivering omni-directional sound, making placement more flexible and less critical. With its rugged construction and weather-resistant build, the IOSUBP is ideal for enhancing outdoor spaces like pools, patios, gardens, and landscaped areas with deep, immersive bass.
Key Subwoofer Specifications
  • Description: 10" Indoor/Outdoor Bluetooth 2.1 Channel Powered Subwoofer
  • Woofer: 10" Polypropylene Cone
  • Frequency response: 40-300 Hz
  •  Impedance: 4 ohms
  •  Low pass filter: Variable
  •  Ingress protection rating: IP66
  • Color: Black
  • Dimensions: 12.2" x 16.5" x 16.5"
Dayton Audio IO655WT 6-1/2" 2-Way Indoor/Outdoor Speaker
Outdoor sound this good has never been so affordable! The IO655 speakers from Dayton Audio provide excellent sonic performance and famous Dayton Audio value in a compact, elegant package that's easy to mount anywhere -- indoors or outdoors. Each IO655WT speaker features a mineral-filled poly cone 6-1/2" woofer and metalized Mylar 1" dome tweeter, for full-range high fidelity performance. The crossover network was computer optimized by Dayton Audio and then fine-tuned via extensive listening tests.
Versatility
Flexibility makes the IO655WT a perfect go-to speaker in any type of install. With 70V/100V transformer taps, the speaker can be used in commercial installations such as background music and paging systems in bars, hotels, conference rooms, and offices. In addition, the IO655WT includes an 8-ohm bypass option for use with consumer amps for residential applications such as pools, patios, gardens, and porches. The IO655WT is a great option for virtually any installation, residential or commercial. Includes yoke-style mounting brackets, stainless steel hardware, and corrosion-resistant nickel plated push terminals for fast installation and wiring.
Part Number310-1514
UPC848791011559
Weight46.16
