  • Dayton Audio ND140-PR 5-1/4" Aluminum Cone Passive Radiator
Dayton AudioPart # 290-217
Model: ND140-PR
The Dayton Audio ND140-PR 5-1/4" passive radiator makes it easy to tune small enclosures lower without increasing overall enclosure size. With a one-piece aluminum cone, rubber surround, high excursion capability, and easily adjustable mass, this passive radiator is perfect for building extremely compact speaker systems capable of incredible low frequency output.
  • Rigid black anodized aluminum alloy cone
  • High excursion capability: 18 mm peak to peak
  • Same "family look" as ND Series woofers
  • Adjustable mass for a vast range of tuning frequencies
Your Price: $14.29
Save $4.70 (25%)
We'll send you an email when Dayton Audio ND140-PR 5-1/4" Aluminum Cone Passive Radiator is back in stock or available for preorder.
Tune small enclosures with Dayton Audio's ND140-PR 5-1/4" passive radiator in speaker designs where a conventional port is not a viable option. This compact passive radiator includes all of the features you expect with larger radiators including high excursion capability, aluminum cone, rubber surround, and adjustable mass. Visually identical to Dayton Audio's popular ND series drivers, the ND140-PR can be used with any small speaker. The threaded rod and included wing nut on the back of the cone makes it easy to add mass to tune the radiator as needed for your projects. Whether you are building a multi-driver array, sound bar, or portable Bluetooth speaker, the Dayton Audio ND140-PR introduces a new range of possibilities.
The ND140-PR 5-1/4" passive radiator includes:
(1) Passive radiator
(2) 18.5 gram disk weights
(1) Wing nut
Specifications: • Fs: 44.2 Hz • Vas: 0.30 cu. ft. (8.4 liters) • Qms: 4.02 • Cms: 0.79 mm/N • Mms: 16.4g • Rms: 1.13 kg/s • Sd: 86.6 sq. cm. • Xmech: 9 mm • Dimensions: Overall diameter: 5.5", Cutout diameter: 4.75", Depth: 2.5".
Tip: As a general rule, the passive radiator(s) should have at least double the displacement of air (Vd) as the active woofer(s)/subwoofer(s) in the system.
To calculate Vd: Sd x Xmax = Vd
ModelND140-PR
Part Number290-217
UPC848791004858
Weight0.5
Nominal Diameter5-1/4"
Bolt Circle Diameter5.43
Resonant Frequency (Fs)44.2Hz
Mechanical Q (Qms)4.02
Compliance Equivalent Volume (Vas)0.3ft³
Mechanical Compliance of Suspension (Cms)0.79mm/N
Diaphragm Mass Inc. Airload (Mms)16.4g
Maximum Linear Excursion (Xmax)9mm
Surface Area of Cone (Sd)86.6cm²
Cone MaterialAluminum
Surround MaterialFoam
Overall Outside Diameter5.5"
Baffle Cutout Diameter4.75"
Depth2.5"
