  • Dayton Audio IC184-7 4.7mH 18 AWG Laminated Steel I-Core Speaker Crossover Inductor Coil
Dayton AudioPart # 257-666
Model: IC184-7
Dayton Audio 18 gauge laminated silicon steel I-core inductors are the most cost effective choice when large inductance values are needed for subwoofer crossovers. Features fully annealed refined copper wire with baked enamel insulation, wrapped around a laminated steel core. In addition, all of the Dayton Audio laminated steel I-core inductors include slotted mounting holes for simple and secure installation.
  • Laminated silicon steel core construction minimizes DC resistance and size while lowering saturation distortion
  • Highly refined copper wire ensures long life and reduced DC resistance
  • Baked enamel insulator creates a durable and airtight protection to prevent corrosion
  • 18 gauge construction to safely handle up to 250 watts RMS
  • Tight ±3% tolerance keeps unit to unit value consistent
Your Price: $11.39
MSRP: $14.99
Save $3.60 (24%)
We'll send you an email when Dayton Audio IC184-7 4.7mH 18 AWG Laminated Steel I-Core Speaker Crossover Inductor Coil is back in stock or available for preorder.
Dayton Audio 18 gauge steel I-core inductors are the most cost effective choice when large inductance values are needed for subwoofer crossovers. Features fully annealed refined copper wire with baked enamel insulation, wrapped around a laminated silicon steel core. Furthermore, all Dayton Audio laminated steel I-core inductors come with slotted mounting holes for easy and secure installation. Each inductor is constructed with a 1-1/4" square x 1-3/4" long plastic bobbin encasing a 1/2" x 3" laminated silicon steel core.
Specifications: • Inductance: 4.7 mH • Wire gauge: 18 AWG • Core type: Laminated silicon steel (maximum 3% silicon) • DC resistance: 0.47 ohms • Tolerance: ±3% • Power handling: 250 watts RMS • Dimensions: 1.57" H x 1.5” W x 2.4" long plastic bobbin around a 0.5" square x 3" laminated silicon steel core.
ModelIC184-7
Part Number257-666
UPC848791008382
Weight0.6
DCR0.47Ω
Inductance4.7mH
Inductor TypeSolid Core
Wire Gauge18
