  • Dayton Audio Gloss White OPAL1 and 2 x 200 Watt A400 Stereo Amplifier Bundle
Dayton AudioPart # 300-4610
Immerse yourself in the unparalleled auditory experience with the Dayton Audio OPAL1 2-Way Hi-fi Speaker. Engineered with precision, it features the innovative 5.5” Dayton Audio MMAG woofers and dual passive radiators, alongside the celebrated Dayton Audio silk dome tweeter. Paired with the Dayton Audio A400 Amplifier, this system delivers high-quality sound through superior performance and great value, offering up to 300 watts per channel at 4 ohms, and 500 watts RMS when bridged. It ensures cool, quiet operation during lengthy listening sessions and provides flexible connections, supporting both RCA and XLR through gold-plated ports, while allowing complex configurations with multiple amplifiers.
  • Advanced MMAG Woofers: Utilizes patented MMAG technology for accurate, distortion-free bass.
  • Dual Passive Radiators: Enhances low-end response for deep, resonant bass without an external subwoofer.
  • Silk Dome Tweeter: Delivers crystal-clear highs with exceptional sound dispersion
  • Optimized Crossover Design: Ensures a harmonious blend of frequencies for immersive sound.
  • Class AB topology for cleaner, crisper sound with remarkably low distortion
  • Unique symmetrical circuit design and transformer placement for balanced audio
  • Ability to deliver up to 300W RMS per channel or up to 500W RMS when bridged
Dayton Audio OPAL1 Bookshelf Speaker Pair Gloss White
Price: $499.00Part # 300-4601
See all items in Stereo Systems
Your Price: $1,099.98
MSRP: $2,289.96
Save $1,189.98 (52%)
Dayton Audio Gloss White OPAL1 and 2x200 Watt A400 Stereo Amplifier Bundle
The Perfect Marriage
Dayton Audio OPAL1 2-Way Hi-Fi Bookshelf Speaker Pair
Since its establishment, Dayton Audio has been synonymous with premier loudspeaker components, and ready-to-build designs. During our research and development process to develop new and interesting loudspeaker concepts one design reigned supreme – OPAL1. This system embodies our commitment to innovation, exclusively incorporating Dayton Audio’s technology, ensuring an audio experience that is both authentic and groundbreaking.
At the heart of the Dayton Audio OPAL1 speaker is a woofer utilizing dual-gap MMAG (Multiple Magnetic Air Gap) technology, allowing for extreme cone excursion, low distortion, and high power handling. Its stiff yet lightweight carbon fiber cone and engineered surround profile ensure smooth midrange performance, a rare feat for a 5.5” woofer. The top octaves are managed by Dayton Audio's premier silk dome tweeter, featuring a coated silk dome and vented aluminum voice coil former for increased power handling and reduced distortion. The tweeter and woofer are seamlessly integrated by an asymmetric crossover centered at 2,300Hz, producing a smooth, non-fatiguing, and ultra-transparent sound. The OPAL1's performance defies its compact size, offering sound quality typically found in larger tower speakers.
The bass extension of OPAL1 comes from the use of a pair of passive radiators on the rear of the enclosure. These allow for ultra-low frequency extension in a small package, besting many 6-1/2” or 8” bookshelf speakers, or even small towers. With a footprint of less than 67 square inches, OPAL1 is capable of average in-room extension nearing 30 Hz. This means in many applications these speakers can create room-filling bass without the need of a separate subwoofer. With an RMS power handling of 200 watts, they can achieve output capability beyond most bookshelf speakers of this size.
Dayton Audio A400 2x200 Watt Stereo Amplifier
The A400 Amplifier makes an immediate visual impact with its classic, yet contemporary aesthetics. Crafted with an emphasis on simplicity and elegance, it adds a touch of sophistication to any space. The faceplate, fashioned from brushed aluminum, and oversized knob commands respect in a 3U package.
Built with a well-ventilated chassis, the A400 Amplifier runs cool even during extensive listening sessions and the unique symmetrical circuit design, and transformer placement, enhances balance and consistency in your audio experience, because of this, no noisy fan is required.
 The Class AB topology of the A400 provides a 100dB Signal-to-Noise Ratio for cleaner, crisper sound, with a remarkably low %0.05 THD+N while providing up to 300W RMS per channel at 4 Ohms (600W Peak). For higher-powered use, the A400 can be bridged with the ability to deliver 500W RMS mono at 8ohms with %0.01 THD+N.
Versatile and professional, the A400 amplifier is designed to meet all your audio needs with ease. Building upon its exceptional performance, this amplifier offers a seamless switch between balanced and unbalanced inputs, accommodating both RCA and XLR connections effortlessly. Whether you prefer the convenience of RCA cables or the enhanced audio quality of XLR cables, the A400 has you covered.
The 12V Trigger inputs and outputs enable seamless power management in your home audio system, ensuring compatibility across various triggering systems for easy integration. To enhance your listening experience, the front LED power can be controlled via a rear switch, preventing distractions from bright lights.
Audtek 14 AWG 6ft Professional Grade Braided Speaker Cable Pair
Using Audtek’s speaker cable with gold plated banana plugs eliminates the hassle of unscrewing binding posts, stripping wires, and retightening. It solves the problem of closely spaced dual binding posts that are difficult to access and binding posts without a hole in the shaft for bare wires. This setup prevents the wire from slipping out during tightening, ensuring a high-quality connection every time and avoiding unnecessary aggravation.
Audtek banana plug 14 AWG speaker cable’s design delivers the ultimate in high quality performance. Each conductor has 16 layers of 7/34 gauge OFC strands twisted around each other to keep the signal constant all the way to your speakers. The gold-plated banana plugs ensure a consistent electrical connection and their set screws combined with heat shrink secure the wire inside the plugs. The polypropylene weave prevents accidental damage to the cable’s black PVC outer jacket while the cable pants protect the black and red inner conductor’s PVC insulators that spit into each individual banana plug.
Amplifier Specifications
OPAL1 Specifications
  • 200WPC RMS @4Ω / FTC 20 Hz- 20 kHz / 0.01% THD
  • 160WPC RMS @8Ω / FTC 20 Hz- 20 kHz / 0.05% THD
  • 300WPC RMS @4Ω / FTC 20 Hz- 20 kHz / 0.05% THD
  • 500W RMS @8Ω / Bridged 20Hz-20kHz/ 0.01% THD
  • Frequency Response: 15Hz-20,000Hz
  • Input Sensitivity: 0.43V
  • Minimum Speaker Impedance: 4 Ohm (8 Ohm Bridged)
  • SNR: 100 dB (A-weighted)
  • Dimensions: 17" x 16-11/16" x 5-3/16"
  • Weight: 41.5 lbs.
  • Configuration: Passive 2-Way with dual passive radiators
  • Woofer: 5-1/4" DVC Extended Range Bass Driver with MMAG Technology and carbon fiber cone
  • Tweeter 1-1/8" Reference fabric dome tweeter
  • Nominal Impedance: 8Ω
  • Minimum Impedance: 4.3Ω @ 4,400Hz
  • Frequency Response: 32Hz - 20kHz, -3dB, Half-Space
  • Sensitivity: 78.5 dB SPL
  • Crossover Point: 2,200Hz
  • Power Handling: 200 Watts RMS
  • Maximum Output: 102dB @ rated power
  • Dimensions (WxDxH): 7" x 9-1/2" x 14"
  • Weight: 20.8 lbs.
Part Number300-4610
UPC848791010798
Weight107.65
