  • Dayton Audio DSS4-SN Satin Nickel Speaker Spike Set 4 Pcs.
Dayton AudioPart # 240-719
Model: DSS4-SN
By rigidly coupling a loudspeaker enclosure to a floor by means of a "spiking" system, it is possible to dramatically improve clarity, stereo imaging, and bass response.
  • Dramatically improves clarity, stereo imaging, and bass response
  • Great results when used with subwoofer systems
  • Solid brass construction with attractive plated finish
  • Two-piece tip design for level adjustment
  • Barbed inserts can be mounted from inside or outside the cabinet
Your Price: $52.98
Save $16.01 (23%)
We'll send you an email when Dayton Audio DSS4-SN Satin Nickel Speaker Spike Set 4 Pcs. is back in stock or available for preorder.
By rigidly coupling a loudspeaker enclosure to a floor by means of a "spiking" system, it is possible to dramatically improve clarity, stereo imaging, and bass response. This is especially apparent with subwoofer systems. The Dayton Audio DSS Series spikes are precision machined from solid brass and then plated with a satin nickel finish. Each cone spike weighs 86 grams and measures 1-1/4" diameter and 1-1/2" tall. The two-piece threaded tip design allows for precise level adjustment. Barbed insert nuts and threaded studs are included for mounting internally or externally in cabinets with walls up to 1" thick. Set includes four satin nickel cone spikes, four satin nickel floor discs, four barbed inserts, and four M6 threaded studs.
ModelDSS4-SN
Part Number240-719
UPC844632082399
Weight1
Color / FinishSatin Nickel
Construction MaterialBrass
