  • Dayton Audio DNR-8.0 8 Ohm 10W Precision Audio Grade Resistor
Dayton AudioPart # 004-8
Model: DNR-8.0
Dayton Audio DNR Series "Audio Grade" resistors are used in Zobel networks and fixed L-Pad attenuator circuits for tweeters. Nickel-chromium elements, a high thermal conductivity ceramic core, and welded construction all contribute to their low-noise performance.
Your Price: $1.25
Save $0.74 (37%)
648 In Stock
We'll send you an email when Dayton Audio DNR-8.0 8 Ohm 10W Precision Audio Grade Resistor is back in stock or available for preorder.
Order in the next 1 hr 1 min to ship today. Details
Dayton Audio DNR Series "Audio Grade" resistors are primarily used in Zobel networks and fixed L-Pad attenuator circuits. Nickel-chromium elements, a high thermal conductivity ceramic core, and welded construction all contribute to their low-noise performance. With a precision 2% tolerance, gold-plated oxygen free copper leads, and low-inductive wire wound construction, this resistor is a must for your next speaker crossover project!
Dimensions: 48 mm L x 10 mm W x 10 mm H.
Sold individually.
ModelDNR-8.0
Part Number004-8
UPC844632025785
Weight0.01
CompositionLow-Inductive Wirewound
Power Rating10W
Resistance8Ω
Tolerance2%
