  • Dayton Audio DMPC-75 75uF 250V Polypropylene Capacitor
CLEARANCE Dayton Audio DMPC-75 75uF 250V Polypropylene Capacitor
Dayton Audio
Part #027-445
Dayton Audio
Part #027-445
Model: DMPC-75
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
  • 250 VDC rating
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 45 mm x 75 mm
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers. Large values are great for 3-way speaker designs.
• Value: 75.0 µF
• Rated: 250 VDC
• Tolerance: ±5%
• Dielectric Strength: 150%
• Dimensions: 45 mm Dia. x 75 mm L.
ModelDMPC-75
Part Number027-445
UPC844632016332
Weight0.2
Capacitance75 uF
Tolerance5%
Voltage Rating250V
