Dayton Audio DBPP-BK Double Binding Post Plate Black Anodized
We'll send you an email when Dayton Audio DBPP-BK Double Binding Post Plate Black Anodized is back in stock or available for preorder.
Looking for a higher-performance alternative to standard terminal cups? The Dayton Audio binding post plates are the answer. Made from 0.110" brushed aluminum with a black anodized finish. A pre-installed gasket and beveled outside edge allow easy installation without requiring time-consuming recesses. Simply attach your choice of binding posts to the plate, cut a hole in your cabinet with a jig saw or hole saw, and screw in place. Designed to work with your choice of Dayton Audio Premium Binding Posts.
Specifications: Black anodized finish • Accommodates two pairs of binding posts • Overall Dimensions: 4" W x 5.5" H (100.3 mm x 140.4 mm) • Maximum Cabinet Cutout: 2.75" W x 4.5" H (69 mm x 115.4 mm) • Hole Spacing: 30 mm x 50 mm • Hole Diameter: 0.453" (11.5 mm) • Corner Radius: 0.315" (8 mm)
Product Details | |
| Brand | Dayton Audio |
| Model | DBPP-BK |
| Part Number | 091-612 |
| UPC | 844632001369 |
| Unit of Measure | Each |
| Weight | 0.3 |
Product Specifications | |
| Contact Plating | N/A |
| Style / Type | Mounting Plate |
