  • Dayton Audio DAX88IR IR Remote for DAX88
Dayton AudioPart # 300-991
Model: DAX88IR
Dayton Audio's DAX88 8-Source, 8-Zone Distributed Audio Matrix Amplifier delivers the new standard of the multi-zone Wi-Fi audio experience. Providing six stereo amplified zones and two stereo line-level preamp zones, the DAX88 offers the ultimate flexibility in distributed audio for your home or business. The DAX88IR remote control gives you access to a zone's function, including volume, power, source selection, mute, treble, and bass.
  • Handheld remote control allows you to adjust a zone's volume, power, source selection, mute, treble, and bass
Your Price: $11.29
MSRP: $14.99
Save $3.70 (25%)
We'll send you an email when Dayton Audio DAX88IR IR Remote for DAX88 is back in stock or available for preorder.
Dayton Audio's DAX88 8-Source, 8-Zone Distributed Audio Matrix Amplifier hands you the definitive multi-zone Wi-Fi audio experience. The flexibility of six stereo amplified zones and two stereo line-level preamp zones allow you to use the DAX88 with your choice of speakers. Whether installed for residential or commercial use, the DAX88 provides you complete sonic freedom. Plain and simple.
Using the DAX88 keypad's IR target, the DAX88IR remote control allows you to adjust all keypad functions. The remote gives you control over power, mute, volume, bass, treble, balance, and source selection. Note: A DAX88KP is required for the remote control to operate.
1. Mute: Mute/un-mute current zone
2. Source: Select source playing in current zone
3. Volume Adjust volume of current zone
4. Balance: Adjust the L/R balance of current zone
5. Zone Power: Power ON/OFF current zone
6. Bass Control: Adjust bass level of current zone
7. Treble Control: Adjust treble level of current zone
Functions controlled:Volume, zone power, source selection, bass, treble, mute
Battery:2 x AAA
Dimensions: 5-3/4" H x 1-5/8" W x 3/4" D
The Complete DAX88 Line Up
Your Home Your Music Total Control
Dayton Audio's DAX88 8-Source, 8-Zone Distributed Audio Matrix Amplifier hands you the definitive multi-zone Wi-Fi audio experience. With a comprehensive and straightforward to use mobile control app, Matrio™, the DAX88 liberates you to listen to your music on your terms, no matter where you are in your house. The flexibility of six stereo amplified zones and two stereo line-level preamp zones allow you to use the DAX88 with your choice of speakers. Whether installed for residential or commercial use, the DAX88 provides you complete sonic freedom. Plain and simple.
Your Music Your Way
Dayton Audio's Matrio™ mobile app simplifies your audio system by giving you, and other users access to multi-zone control from your mobile devices. With the ability to select between eight sources and eight zones, Matrio™ streamlines personalized audio experiences across multiple rooms. Matrio™ allows you to change sources, adjust volume, tone, and balance for zones, as well as group zones. Enjoy whole-home audio immersion without needing to move from where you are.
Demo Matrio™ Now
Download the app for free from the iOS App Store or Google Play and fully explore Matrio™ in demo mode without a DAX88 unit.
Control From Your Wall
If you need quick, accessible zone control, the DAX88 gives you the ability to access total command of the DAX88 via in-wall keypads. You can connect up to eight keypads throughout your home or business that give you direct control over volume, power, bass, treble, mute, and source selection. The keypad has a built-in IR target for use with the DAX88 remote. Also, the keypad has an external IR target terminal if you want to use an additional target in another location.
All Together Now
The DAX88 allows you to connect up to eight control keypads per device. With the DAX88HUB, you can connect all of your keypads to the DAX88 with one ethernet connection. Each keypad connects directly to the DAX88HUB via an ethernet cable. The DAX88HUB then connects to the DAX88 with a single ethernet cable to simplify installation and reduce wire clutter.
ModelDAX88IR
Part Number300-991
UPC848791007330
Weight0.1
