  • Dayton Audio D40T 40W PA Speaker Horn Driver with 70V Transformer
Dayton AudioPart # 300-198
Model: D40T
The Dayton Audio D40T (40W) is a lower power horn driver for medium to high SPL requirements. This lower rating may be more appropriate for smaller jobs.  The D40T uses a phenolic-impregnated cloth diaphragm for crisp, articulate sound. This driver has the sound quality you have come to expect from Dayton Audio products.  It is perfect for PA, and tougher than a two-dollar steak!
  • 40 watts RMS power handling capacity for high SPL output
  • Durable phenolic-impregnated diaphragm creates a smooth frequency response
  • Low distortion, high output
  • Integrated 70V transformer with selectable taps for convenient installation
  • 1-3/8” -18 TPI threaded horn coupling fits most standard horns
  • Improved gasket for weatherproof reliability
  • Five-year warranty guarantees durability
AtlasIED PD-5VH 40W Compression Driver
Price: $236.99Part # 242-858
See all items in PA Horn Drivers
Your Price: $49.98
Save $15.01 (23%)
We'll send you an email when Dayton Audio D40T 40W PA Speaker Horn Driver with 70V Transformer is back in stock or available for preorder.
Perfect for PA and tough as a two-dollar steak
Key Specs:
  • Exit Diameter: 1"
  • Power Handling (RMS): 5W, 10W, 20W, 40W
  • Impedance: 70v
  • Frequency Response: 160 - 8000 Hz
  • Sensitivity: 107 dB 1W/1m
  • Voice Coil Diameter: 2"
  • Voice Coil Material: Kapton / Copper
  • Full SpecificationsManual
Frequency Response
The Dayton Audio DA40T has a response that lends itself well for paging and PA use due to its efficiency in the frequency range of human voices and midrange detail of stringed instruments. The impedance curve of the DA40T is easily manageable for verstile, simple system designing!
Integrated 70V Transformer
The Dayton Audio D40T is ready to install anywhere! With its' built-in 70V transformer, selectable taps allow you to customize the output of each speaker to suite a multitude of locations and circumstances. Use the higher rated taps for tall vaulted ceilings or anywhere you need high SPL requirements, the lower rated taps are available for use with setups that have lower SPL requirements such as walking paths or information booths!
Salt-Spray Tested
Contractors, installers, and other audio professionals can feel confident in the D40T’s materials and engineering. A cast aluminum faceplate, gasketed rear housing, and stainless-steel hardware ensure long-term reliability, indoors or out. Dayton Audio has even gone a step further in the development of the D40T with long-term environmental testing, ensuring the longevity and durability of your investment.
We've Got Your Back
Learn More
Shop All Dayton Audio 70V Horn Drivers
Dayton Audio's D1075T 70V horn driver has been a top seller and industry staple for contractors, installers, and other audio professionals for many years. Due to that success, Dayton Audio has expanded the 70V driver line by adding the D40T and D100T. Dayton Audio has garnered an outstanding reputation over the years because they consistently deliver high-quality products at very reasonable prices for installers like you!
D40T
  • Power Rating: 5W, 10W, 20W, 40W
  • Frequency Response: 200Hz-20kHz
  • Shop Now
D1075T
  • Power Rating: 25W, 30W, 50W, 75W
  • Shop Now
D100T
  • Power Rating: 12.5W, 25W, 50W, 100W
  • Shop Now
WOW!!!
This has got to be the best high performance horn driver that I ever used. I attached these drivers to the Dayton 16" horns and all that I can say is WOW!! I'm truly impressed and should have purchased these drivers and horns when I first saw them offered at parts express. The clarity, power, and easy transformer matching, make these Dayton drivers and horns, the best bang for any buck. Definitely money well spent. I will uses these for future applications as more totally awesome sound coverage arises. -DJDOUG
Additional Resources
Woofer Selection Guide
We've made it easier to find the woofer that fits your specific application, whatever that may be. This guide contains every woofer we carry, along with suggested optimum box dimensions, countless driver parameters, and more. All of this is contained in an easy-to-use, sortable guide to help you choose the perfect woofer.
Learn More
Woofer Replacement Tool
Easily replace damaged or worn out drivers in you speaker system to bring them back to their former glory. The Woofer Replacement Tools helps you determine the correct woofer to replace your current driver. This easy to use tool will get your speaker system back up and running quickly.
Learn More
Speaker Building Glossary
Build your speaker building knowledge with a vast glossary of all speaker and speaker building terminology you will encounter.
Learn More
Build Your Own Speaker
To answer some of the questions you may have concerning loudspeaker design that takes you step by step through the build.
Learn More
THE Definitive Collection...The Speaker Building Bible
Through out the years, we have collected the best resources into the Speaker Building Bible. Click the link below to do a deep dive into speaker building.
ModelD40T
Part Number300-198
UPC848791008092
Weight5.25
Diaphragm MaterialPhenolic
Exit Diameter1"
Mounting Type1-3/8"-18 TPI
Power Handling (RMS)40 Watts
