  • Dayton Audio CS1200 Replacement Grille - Gray
NEW Dayton Audio CS1200 Replacement Grille - Gray
Dayton AudioPart # 300-283
Model: CS1200-2-GRILL
Upgrade or replace your broken or worn-out Classic Series subwoofer grilles with these high-quality replacements from Dayton Audio. Crafted from durable 18mm thick MDF and sturdy grille cloth, these grilles are precision-engineered to perfectly fit Dayton Classic Series subwoofers. Whether you're restoring a damaged grille or giving your speakers a fresh new look with a different color, these replacement grilles offer a stylish and functional solution to enhance both protection and aesthetics.
  • Perfect Fit for Classic Series Subwoofers: Precision-engineered to seamlessly match Dayton Audio Classic Series subwoofers.
  • Durable 18mm MDF Construction: Built to last, offering exceptional protection for your speaker components.
  • Premium Grille Cloth: Stylish and sturdy grille cloth enhances speaker aesthetics while safeguarding the drivers.
  • Ideal for Restoration or Upgrades: Replace broken, damaged, or aging grilles to restore or revamp your speakers.
  • Easy Installation: Designed for a hassle-free replacement process, saving you time and effort.
  • Enhanced Protection: Shields your speakers from dust, debris, and accidental impacts while maintaining audio performance.
  • Customizable Appearance: Available in multiple color options to match your space and style.
Dayton Audio CS1200 Replacement Grille - Black
Price: $26.00Part # 300-282
See all items in Rough-in Kits, Brackets & Grills
NEW $26.00
Save $7.99 (24%)
We'll send you an email when Dayton Audio CS1200 Replacement Grille - Gray is back in stock or available for preorder.
Upgrade or replace your broken or worn-out Classic Series speaker grilles with these high-quality replacements from Dayton Audio. Crafted from durable 18mm thick MDF and sturdy grille cloth, these grilles are precision-engineered to perfectly fit Dayton Classic Series subwoofers. Whether you're restoring a damaged grille or giving your speakers a fresh new look with a different color, these replacement grilles offer a stylish and functional solution to enhance both protection and aesthetics.
The Dayton Audio CS1200 replacement grilles are the perfect solution for replacing broken, damaged, or lost speaker grilles, ensuring your speakers remain protected and functional. Designed to safeguard your drivers from curious fingers, pets, and accidental impacts, these durable replacement grilles help maintain the performance and longevity of your audio equipment. With easy installation and a precise fit for Dayton Audio CS1200 subwoofer, these grilles not only restore protection but also keep your speakers looking sleek and professional.
The Dayton Audio CS1200 replacement grilles offer more than just protection—they also provide an easy way to refresh the style of your Classic subwoofers. By swapping grille finishes, you can give your speakers a whole new look, seamlessly blending them with your updated décor. Whether you're aiming for a modern upgrade or a subtle style change, these versatile grilles allow you to customize your audio setup while maintaining durability and functionality.
ModelCS1200-2-GRILL
Part Number300-283
UPC848791011665
Weight1.6
Nominal Diameter14" x 14""
