  • Dayton Audio B40 2.1 Vinyl Audio Bundle with 8" 150W Powered Subwoofer Black
Dayton AudioPart # 300-2000
Delivering big, immersive sound from a compact footprint, the Dayton Audio desktop stereo system is the perfect solution for dorm rooms, offices, and bedrooms where space is limited but sound quality matters. A tube-driven amplifier adds rich warmth and musical character, while built-in Bluetooth makes wireless streaming fast and effortless. Two analog inputs provide easy connection for additional sources, including TVs, CD players, and Wi-Fi streamers, and vinyl playback is seamless with the Dayton Audio TT-1BT turntable for authentic analog sound. For late-night listening, the integrated headphone amplifier ensures excellent clarity without disturbing others, and when full-range performance is desired, the CS800 powered subwoofer delivers deep, controlled bass that brings music, movies, and games to life—creating a versatile, great-sounding stereo system that punches well above its size.
  • Compact system with full-range sound designed for dorm rooms offices and bedrooms
  • Tube driven amplifier design adds natural warmth musicality and dynamic control
  • Integrated Bluetooth streaming enables convenient wireless playback from phones tablets and computers
  • Multiple analog inputs provide flexible connectivity for TVs CD players radios and Wi-Fi streaming devices
  • Turntable ready performance with seamless integration for the Dayton Audio TT-1BT turntable
  • Built in headphone amplifier allows detailed private listening without disturbing others
  • Enhanced low frequency extension from the CS800 powered subwoofer delivers clean controlled bass for music movies and gaming
Your Price: $588.00
MSRP: $880.95
Save $292.95 (33%)
Classic Tube Warmth with Contemporary Design
At the heart of this stereo is a hybrid tube amplifier with vintage flair and modern connectivity. By combining a tube preamp with a contemporary solid-state amplifier, the HTA20 provides the warm and fuzzy sound characteristics associated with vintage tube amplifiers while generating clean and efficient power common in modern amplifiers. Simply stated, this will sound amazing while remaining as energy-efficient as possible. Eliminate the hassle of long cables and go completely wireless with the built-in Bluetooth streaming, or connect any analog device to the two RCA inputs for easy integration into any desktop system.
Dayton Audio TT-1BT Belt Drive Turntable
The Dayton Audio TT-1BT Belt Drive Turntable is a versatile and high-quality turntable that combines modern technology and delivers a classic vinyl listening experience. With its built-in USB and Bluetooth connectivity, you can easily connect it to your computer or speakers and enjoy your vinyl records in exceptional audio quality. The upgraded Audio Technica AT-VM95E Cartridge ensures outstanding playback performance, delivering clear and detailed sound. Whether you're a vinyl enthusiast or a beginner, this turntable offers convenience and superior sound reproduction, making it a fantastic choice for any music lover.
Dayton Audio Classic Collection B40 Bookshelf Speakers
Enhance your listening experience with these small yet impressive bookshelf speakers. These compact, unobtrusive speakers use a real 2-way crossover and are wall mountable and the black ebony finish blends in to any décor. The Classic Collection B40 uses a sturdy wood-composite cabinet that minimizes resonance and enhances warmth without sacrificing clarity.
Dayton Audio Classic Collection CS800 Powered Subwoofer
Renowned for setting new standards in audio performance, Dayton Audio takes things to the next level with the Classic Collection powered subwoofers. Available in 8", 10", and 12" sizes and two finishes, these subwoofers feature rugged, tank-like construction and a striking design that perfectly matches the rest of the Dayton Audio Classic Collection family of speakers. Engineered to deliver deep, powerful bass, they consistently exceed expectations—making them true overachievers in both form and function.
What's Included
• HTA20 Hybrid Stereo Tube Amplifier with Bluetooth
• TT-1BT Belt Drive Turntable
• B40 4" 2-Way Bookshelf Speaker Pair
• CS800 8" 150W Powered Subwoofer
• Speaker & Subwoofer Cables
• Power output: 12 watts RMS x 2 into 4 ohms
• Total Harmonic Distortion: <0.1% @ 12W per channel
• Minimum speaker impedance: 4 ohms
• Frequency response: 20-20,000 Hz ±2 dB
• Channel separation: 65 dB
• Dynamic range: >80 dB
• Signal-to-noise ratio: >80 dB
• Preamplifier tube: 6F2 x 2
• Headphone amp output: 3.5 mm, 15 mW @ 600 ohms; 11 mW @ 300 ohms; 7.8 mW @ 32 ohms; 5.6 mW @ 16 ohms (maximum @ 1 kHz, <1% THD+N)
• Transistors: Toshiba 1941/5198
• Bluetooth version: AC6905A CSR 4.2
• Input impedance: 47k ohms (minimum)
• Input sensitivity: 300 mV
• Power: 110/220V, 50/60 Hz
• Dimensions: 4.2" H x 9.3" W x 6.18" D
• Drive Type: Belt Drive
• Cartridge: AT-VM95E
• Type: Moving Magnet
• Nominal Speeds: 33-1/3 RPM, 45 RPM
• Speed Variance: +/- 1%
• Wow and Flutter: ≤0.15%
• Signal-to-noise Ratio: 55 dB
• Bluetooth Version: 5.0
• Bluetooth Codecs: Qualcomm aptX
• USB Output Sample Rates: 44.1 and 48 kHz
• Power Consumption: 6W
• AC Adapter: 12V, 500mA DC
• Dimensions (W x D x H): 16.55” x 13.6” x 4.9”
• Weight: 13.67 lbs.
• Woofer: 4" polypropylene cone with 4-layer voice coil
• Tweeter: 1" polycarbonate dome with ferrofluid cooling
• Power handling: 50 watts RMS/100 watts max
• Impedance: 6 ohms
• Frequency response: 85-20,000 Hz
• Sensitivity: 82 dB 1W/1m
• Dimensions: 9.5" H x 5.5" W x 5.7" D
• Woofer: 8" Mineral filled paper cone with 4-layer voice coil
• Amplifier: 150W RMS Class D
• Frequency Response: 35 - 200 Hz
• Line Level Inputs: Stereo RCA, LFE
• Speaker Level Inputs: Spring Terminals with Passthrough
• Lowpass Filter: 40 - 160 Hz
• Phase Control: 0º / 180º
• Auto On: Yes
• Dimensions: 12.37" H x 11.5" W x 14" D
• Weight: 22.8 lbs. (10.34 kg)
Part Number300-2000
UPC848791011818
Weight28.7
