  • Dayton Audio 4-Pack of TT20-8 Tactile Transducer Mini Bass Shakers
AC InfinityPart # 295-1247
Model: TT20-8 4-Pack
A 4-pack of Dayton Audio TT20-8 mini bass shakers tactile transducers deliver immersive tactile bass by converting low-frequency audio into vibration you can feel. Ideal for sim racing rigs, gaming chairs, and wearable haptic feedback devices, these compact bass shakers add subwoofer-like impact without taking up floor space or increasing room noise. This bundle makes it easy to build a multi-point tactile feedback system with stronger, more evenly distributed tactile response.
  • Converts low-frequency audio into physical vibration for immersive bass you feel, not hear
  • Nearly silent operation ideal for late-night listening or gaming without disturbing others
  • Compact design allows flexible mounting on chairs, gaming rigs, and small platforms
  • Multi-unit 4-pack enables even vibration distribution across larger surfaces
  • Flexible wiring options support series or parallel configurations for system compatibility
Dayton Audio Tactile Transducer Mini Bass Shaker 8 Ohm TT20-8
Price: $15.98Part # 295-247
See all items in Bass Shakers
Your Price: $49.98
Save $33.01 (40%)
Order in the next 1 hr 6 min to ship today. Details
Feel Subtle Details and Immersive Low-Frequency Effects
The TT20-8 mini bass shaker tactile transducer converts low-frequency audio signals into mechanical vibration, allowing users to feel bass instead of relying only on sound. This creates a more immersive experience for gaming, sim racing, and haptic feedback devices where physical feedback enhances realism. By transferring energy directly into the structure it is mounted to, the shaker produces impactful low-frequency effects without requiring high sound pressure levels. This makes it an efficient solution for adding tactile bass in environments where traditional subwoofers may not be practical. The result is a deeper connection to audio content through physical sensation.
Silent operation makes these tactile transducers an ideal choice for users who want strong bass impact without disturbing others. Because the TT20-8 focuses on vibration rather than airborne sound, it delivers powerful low-frequency effects while keeping overall noise levels low. This allows for late-night gaming or movie sessions without compromising the experience. It also reduces reliance on large subwoofers in shared living spaces. The design provides a clean, controlled, and compact way to introduce tactile bass into a system.
Compact Design for Precise Multi-Point Tactile Feedback
The compact design of each mini bass shaker allows for flexible installation across a wide range of applications. These tactile transducers can be mounted to gaming chairs, sim racing rigs, or integrated into wearable haptic feedback systems with minimal effort. Their small footprint makes them easy to position for optimal performance without worrying about limited space. This flexibility allows users to fine-tune placement for the most effective tactile response. The design supports both simple installations and more customized multi-channel setups.
Using a 4-pack of bass shakers significantly improves tactile performance by distributing vibration across multiple points. Instead of concentrating energy in one location, multiple transducers create a more balanced and realistic tactile field. This is especially beneficial for sim racing rigs and multi-point mounting on chairs where consistent feedback is important. It also enables stereo or multi-channel tactile effects when paired with the right amplifier. The result is a more immersive and evenly distributed bass experience.
Flexible Wiring Options for Easy System Integration
Flexible wiring options make it easy to integrate four TT20-8 tactile transducers into different system configurations. Users can wire the mini bass shakers in series, parallel, or combinations of both to match their amplifier requirements. This adaptability allows for better system optimization and simplifies installation. It also provides room for future expansion or reconfiguration as needs change. The wiring flexibility makes this 4-pack a practical and scalable solution for building a tactile bass system.
Specifications (Each TT20-8):
  • Power handling: 15 watts RMS/30 watts max
  • Impedance: 8 ohms
  • Re: 7.7 ohms
  • Le: 0.35 mH @ 1k Hz
  • Fs: 106 Hz
  • Usable frequency response: 80-400 Hz
  • Dimensions: 2" dia. x 3/4" depth
ModelTT20-8 4-Pack
Part Number295-1247
UPC848791012433
Weight0.8
ApplicationHaptic Feedback
Power Handling (RMS)15 Watts
Impedance8Ω
