  • DataComm 45-0017-UWH Split Plate with Flexible Opening Ultra White
NEW DataComm 45-0017-UWH Split Plate with Flexible Opening Ultra White
DataComm ElectronicsPart # 261-5490
Model: 45-0017-UWH
The DataComm split plate with flexible opening enables audio/video wires and cables to pass through the wall behind your TV, amplifier, or other devices. Two interlocking halves combine to make a single bulk cable wall plate.
  • An easy retrofit: the plate splits into two wire-encircling sections
  • Run up to six A/V cables through your wall
  • Both halves of the plate create a virtually seamless design
  • Quick and easy to install
  • Perfect for eliminating connections at the wall
  • Low profile design easily fits behind flat screen TVs
  • Fits standard single-gang low voltage mounting ring
NEW $5.49
We'll send you an email when DataComm 45-0017-UWH Split Plate with Flexible Opening Ultra White is back in stock or available for preorder.
Create a discrete in-wall pass-through for your audio/video cables with the DataComm split plate. Available in white, black, ivory, and lite almond; split plates install in just a few minutes. The bulk wire split plate is installed around existing low voltage cables, eliminating the need to re-pull wires. The low profile design fits behind even the thinnest flat screen televisions and mounts. This DataComm split plate accepts up to six low voltage cables, providing a clean appearance to your home theater setup.
BrandDataComm Electronics
Model45-0017-UWH
Part Number261-5490
UPC660559018064
FinishWhite
