  • Arlington LV1M Heavy-Duty ZINC Single Gang Low Voltage Mounting Bracket
Arlington IndustriesPart # 261-439
Model: LV1M
Plastic can be great, but sometimes you need something a little more rugged to get the job done. That's where the LV1M comes in; the heavy-duty zinc bracket will stand up to far more abuse than its plastic counterpart.
  • More rigid and harder to bend than plastic
  • Adjusts to fit wall thickness from 1/4" to 1"
  • cULus Listed
Your Price: $4.98
We'll send you an email when Arlington LV1M Heavy-Duty ZINC Single Gang Low Voltage Mounting Bracket is back in stock or available for preorder.
Order in the next 8 hr 16 min to ship today. Details
For existing construction, the LV1M is the heavy-duty option that won't bend under pressure. Ideal for communications, cable TV, computer wiring and audio installations, this bracket also serves as a template for its own cut out, as illustrated below. The LV1M will adjust to fit 1/4" to 1" thick wallboard paneling and drywall. Sturdier than plastic, this bracket is an excellent choice for those who demand something more rugged.
Hold the bracket level and trace the inside
Cut the hole out and run wires through
Run wires through the bracket
Tighten the dog-ear tabs and secure the bracket
Secure the insert
Install the cover
BrandArlington Industries
ModelLV1M
Part Number261-439
UPC018997129055
Weight0.2
