  • Dale 22 Ohm 50W Wirewound Chassis Mount Resistor
CLEARANCE Dale 22 Ohm 50W Wirewound Chassis Mount Resistor
AC Infinity
Part #029-2052
AC Infinity
Part #029-2052
Dale 20 ohm 50W wirewound chassis mount resistor. The resistor is surrounded by thick metal for durability and heat displacement.
  • Surrounded by thick metal for durability and heat displacement
  • Heavy duty metal 0.16" W x 0.25" L x 0.04" flat soldering terminals
  • Two screw holes for secure mounting
Dale 20 ohm 50W wirewound chassis mount resistor. The resistor is surrounded by thick metal for durability and heat displacement. Two 0.12" screw holes 1.75"apart for secure mounting. Screws sold separately. Two heavy duty metal 0.16" W x 0.25" L x 0.04" flat soldering terminals with 0.08" holes make it easy to install. The length without the solder terminals is 1.96" and it's 0.64" thick without the screw terminals.
Part Number029-2052
UPC848864066035
CompositionWirewound
Power Rating25W
Resistance22Ω
Tolerance1%
