  • DS18 GEN-X4 4" 2-Way 120W Coaxial Speaker Pair 4 Ohm
CLEARANCE DS18 GEN-X4 4" 2-Way 120W Coaxial Speaker Pair 4 Ohm
DS18Part # 294-8010
Model: GEN-X4
The GEN-X4 4" 2-way coaxial speaker pair from DS18 features Mylar balanced dome tweeters, black paper cones with rubber edges, and sleek mesh grills with red accents. These unique speakers will hit all frequencies with great accuracy and SPL. They boast a fine clarity that is unparalleled by any other speaker in their price range.
  • 4" damped paper cone with stitched rubber surround delivers natural response
  • 1-1/8" Mylar balanced tweeter produces accurate high frequencies with low distortion
  • Standard size for an easy drop-in installation in many factory mounting locations
  • Included grills offer protection with a modern look
  • High performance audio for an exceptional value
We'll send you an email when DS18 GEN-X4 4" 2-Way 120W Coaxial Speaker Pair 4 Ohm is back in stock or available for preorder.
DS18's GEN-X4 4" 2-way coaxial speaker pair combines a paper cone woofer and a large diameter Mylar tweeter for natural full-range response with low distortion. A naturally damped paper cone minimizes unwanted resonances to deliver smooth response throughout the midrange for realistic vocal reproduction. The durable rubber surround is securely stitched to cone to ensure a reliable bond even when exposed to the extreme automotive environment. High frequencies are handled by a 1-1/8" balanced drive Mylar tweeter that offers high efficiency, accuracy, and wide dispersion. With good efficiency and capable of handling up to 40 watts RMS the GEN-X4 will produce impressive output even when driven with modest power.
With a standard size and mounting points, the GEN-X4 is a direct drop-in upgrade for many vehicles. You can expect clarity, detail, durability, and output unmatched by other speakers in this price range.
Note: Grills, speaker wire, and mounting hardware included
Type: 4" 2-way full range
Woofer: 4" damped paper cone
Tweeter: 1-1/8" Mylar dome
Power handling: 40 watts RMS (120 watts max)
Frequency response: 105-20,000 Hz
Sensitivity: 83 dB 1W/1m
Impedance: 4 ohms
Voice coil: 1" diameter
Basket structure: Stamped steel
Mounting depth: 1-11/16"
BrandDS18
ModelGEN-X4
Part Number294-8010
UPC663593063953
Unit of MeasurePairs
Weight2.5
Speaker Size4"
Power Handling (RMS)40 Watts
