  • DS18 GEN-X3000.1D GEN-X 1-Channel Monoblock Class D 3000W Amplifier
CLEARANCE DS18 GEN-X3000.1D GEN-X 1-Channel Monoblock Class D 3000W Amplifier
DS18Part # 294-8166
Model: GEN-X3000.1D
The DS18 GEN-X line of Class D Amplifiers are durable and provide maximum wattage for your budget. These stylish amps will fit just about anywhere and supply all the power you need with great efficiency.
  • Full Range Class D Amplifier
  • 1 channel at 3000 watts max
  • Efficient power handling allows for easy installation of multiple amps
We'll send you an email when DS18 GEN-X3000.1D GEN-X 1-Channel Monoblock Class D 3000W Amplifier is back in stock or available for preorder.
The DS18 GEN-X3000.1D GEN-X 1-Channel Monoblock Class D 3000W Amplifier is a durable Monoblock amplifier for people who want an amplifier that will deliver plenty of power efficiently as possible. The included remote volume control knob allows for easy level adjustment when the amplifier cannot easily be reached.
The GEN-X3000.1D is a powerful single channel amplifier perfect for powering subwoofers. With adjustable low pass filter, phase, and bass boost level and frequency subwoofers can be easily tuned for ultimate response and power. The included remote volume control allows for even further control of your audio system
With 430 watts RMS of power at 4 ohms, 700 watts RMS of power at 2 ohms, and 1000 watts RMS at 1 ohm, the GEN-X3000.1D delivers ultimate power and efficiency.
Power output: 430W RMS (@ 4 ohms), 700W RMS (@ 2 ohms), 1000W RMS (@ 1 ohm)
Frequency Response: 20 Hz - 180 Hz
Total harmonic distortion: 0.08%
Signal-to-noise ratio: 98 dB
Dimensions: 390 mm x 190 mm x 60 mm (15.35" x 7.4" x 2.36")
BrandDS18
ModelGEN-X3000.1D
Part Number294-8166
UPC663593064295
Weight8.4
Input TypeRCA Line Level
Output Channels1
RMS Power Output (4 Ohms)430
