  • DS18 CANDY-6 CANDY 6-Channel Compact Full-Range Class D 1800W Amplifier
CLEARANCE DS18 CANDY-6 CANDY 6-Channel Compact Full-Range Class D 1800W Amplifier
DS18Part # 294-8154
Model: CANDY-6
The DS18 CANDY line of Cass D Amplifiers are compact and powerful. DS18 CANDY will make your ears tingle with pleasure.
  • Full Range Class D Amplifier
  • 6 channels at 1800 watts (300 watts per channel)
  • Compact footprint for installation in small spaces
We'll send you an email when DS18 CANDY-6 CANDY 6-Channel Compact Full-Range Class D 1800W Amplifier is back in stock or available for preorder.
The DS18 CANDY-6 CANDY 6-Channel compact Full-Range Class D 1800W amplifier is the perfect amplifier for people who want a very small footprint and all the benefits that come from larger amplifiers by putting out lots of power in a small package.
The CANDY-6 can be set up to power either full range speakers, subwoofers, or tweeters with it's built in crossovers and adjustable crossover points. Three independent crossovers allow for the ability to power different sets of speakers between the amplifier's six outputs. Each set of outputs has independent level control, filter point adjustment, and crossover operation.
With 120 watts RMS (400 watts max) of power per channel at 2 ohms, 80 watts RMS of power per channel at 4 ohms, the CANDY-6 can also operate in a bridged mono mode for a total output of 240 watts RMS (1600 watts max) at 4 ohms bridged.
Power output: 6 x 80W RMS (@ 4 ohms), 6 x 125W RMS(@ 2 ohms), 3 x 250W RMS (4 ohms bridged mono)
Frequency Response: 10 Hz - 60 kHz
Total harmonic distortion: <0.01%
Signal-to-noise ratio: ≥80 dB
Dimensions: 351 mm x 137 mm x 43 mm (13.81" x 5.39" x 1.69")
BrandDS18
ModelCANDY-6
Part Number294-8154
UPC663593062109
Weight6
Input TypeRCA Line Level
Output Channels6
RMS Power Output (4 Ohms)80
