  • Crown XLi 800 Power Amplifier 2 x 300W at 4 Ohms
Crown AudioPart # 245-5126
Model: XLi 800
The Crown XLi Series is a robust line of two-channel power amplifiers designed to deliver reliable and high-quality sound for professional audio applications. Built with Crown’s reputation for excellence, the XLi Series offers powerful performance, user-friendly features, and durable construction, making it ideal for musicians, DJs, and audio professionals alike. Whether used in live music setups, houses of worship, or home theaters, the XLi Series combines versatility and dependability at an exceptional value.
  • Simple, affordable, and reliable class AB power
  • Stereo, parallel, and bridged-mono operational modes to suit all setups
  • RCA and XLR inputs for flexible input options
  • User selectable input sensitivity of 0.775V and 1.4V to accommodate different sources
  • Efficient forced-air fans to prevent excessive thermal buildup
  • Comprehensive protection circuitry for safeguarding against shorts, no-load conditions, and radio frequency interference
  • LED power, signal, clip, and fault indicators to keep you informed
Crown XLS 1002 DriveCore 2 Power Amplifier 2 x 350W at 4 Ohms
Price: $500.00Part # 245-507
See all items in Power Amplifiers - Live Sound
Your Price: $419.00
MSRP: $520.00
Save $101.00 (19%)
We'll send you an email when Crown XLi 800 Power Amplifier 2 x 300W at 4 Ohms is back in stock or available for preorder.
Crown XLi Series Power Amplifiers
Crown's XLi Series of power amps ushers in a new era of affordability without compromising performance. Mobile DJs, bands, and sound engineers will appreciate the XLi Series' rugged durability as much as houses of worship, discos, and other venues appreciate the pristine sound quality. The XLi 800 puts up to 600 watts of power at your disposal, with enough input/output options to ensure effortless integration and use in virtually any setup. Does your band need to rock the house with a full range PA system? No problem. Or perhaps you're a home theater enthusiast with a need to feed some monster subwoofers? Crown has you covered.
All XLi amps include RCA and XLR inputs, user selectable input sensitivity of 0.755V or 1.4V, speakON and binding post outputs, stereo/parallel/bridge-mono modes, power/fault/signal presence/clip indicators, forced-air cooling; and protection against shorts, no-load, on/off thumps and radio-frequency interference. With over six decades of experience designing and building rock-solid products, Crown sets the standard in amplifier technology.
Crown XLi
The Crown XLi Series power amplifiers offer both RCA and XLR input options, along with speakON and binding post outputs. They feature user-selectable input sensitivity of 0.755V or 1.4V, multiple operating modes including stereo, parallel, and bridge-mono, and LED indicators for power, fault, signal presence, and clipping. These amplifiers are equipped with forced-air cooling and comprehensive protection against shorts, no-load conditions, on/off thumps, and environmental radio frequency interference.
Affordable, reliable, and heavy-duty
Cut the frills and keep things simple. The XLi series is here for when you want nothing more than a power amplifier that is ready to deliver lots of power without fail. Feed those power-hungry subwoofers with these class AB amplifiers and don't just hear the bass, but feel it.
  • Frequency Response: 20 Hz - 20 kHz, +0/-1 dB (at 1 watt)
  • Total Harmonic Distortion (THD): <0.5%, 20 Hz - 20 kHz
  • Intermodulation Distortion: =/ <0.35% (60 Hz and 7 kHz at 4:1 from full rated ouput to -30 dB)
  • Slew Rate: >10V/us
  • Voltage Gain: 29 dB
  • Damping Factor: (8 ohms, 10 Hz to 400 Hz) >200
  • Signal To Noise Ratio (A-weighted): >100 dB
  • Crosstalk (below rated power) 20 Hz to 1 kHz: -75 dB, -59 dB
  • Input Sensitivity (for full rated power at 8 ohms): 0.775V or 1.4V
  • Input Impedance (nominal balanced, unbalanced): 20kΩ, 10kΩ
  • AC Line Voltage and Frequency Configurations Available: (+10%) 120V~60 Hz; 220V~50/60 Hz; 230-240V~50/60 Hz
  • Dimensions: 19" x 3.5" x 12.4" (48.3cm x 8.9cm x 31.5cm)
  • Weight: 28 lbs (11.4 kg)
  • IEC Power Connector: 15A
BrandCrown Audio
ModelXLi 800
Part Number245-5126
UPC871015006895
Weight28.45
Output Channels2
Power Output (RMS Per Channel @ 8 ohms)251 - 500 WattsWatts
Weight Range20 to 29 lbs.
