  • Consolidated 12 AWG 2C Portable AC Power Cable SJOOW 50 ft.
CLEARANCE Consolidated 12 AWG 2C Portable AC Power Cable SJOOW 50 ft.
ConsolidatedPart # 101-626
This SJOOW heavy duty power cable is very flexible and water resistant making it suitable for a variety of indoor/outdoor uses. From high power speaker cables on a professional sound stage, to making or replacing damaged AC cords, the applications for this wire are unlimited.
  • 65/30 AWG ASTM B-174 and UL62 stranded bare copper for best conductivity and flexibility
  • Oil, weather, sunlight, and water resistant for a variety of applications including outdoor use
  • Black neoprene thick jacket with temperature range from -40° to 194° F (-40° to 90° C) 300V
  • UL and CSA approved
We'll send you an email when Consolidated 12 AWG 2C Portable AC Power Cable SJOOW 50 ft. is back in stock or available for preorder.
This heavy duty power cable is very flexible making it suitable for a variety of uses. From high power speaker cables on a professional sound stage, to making or replacing damaged AC cords, the applications for this wire are unlimited. Premium grade black rubber jacket allows good flexibility even in low temperatures.
Specifications: • Temperature range: -40° to 194° F (-40° to +90° C) • Voltage rating: 300 volts • Wire type: 12/2 65/30 AWG stranded bare copper B-174 and UL62 with SJOOW jacket • Insulation: EPDM • Jacket thickness: 0.045" (1.143mm) • Nom. O.D. 0.41" (10.42mm) • Approvals: VW-1 FT2 RoHS and MSHA, UL and CSA • Conductor colors: Black and white • Made in Poland.
BrandConsolidated
Part Number101-626
UPC848864067643
Weight6.15
Cable RatingSJOOW
Conductors2 Conductor
Jacket ColorBlack
Wire Gauge12
