  • Switchcraft 188 1/4" Mono Plug Heavy Duty Nickel
SwitchcraftPart # 093-126
Model: 188
Switchcraft's 1/4" mono plugs have one-piece tip rods for added strength and durability. Features of 188 include solder terminals and a shielded nickel handle.
  • Extra-large cable clamp
  • Long sleeve terminal
  • Handles up to 15A (max)
Your Price: $7.98
MSRP: $16.79
Save $8.81 (52%)
50 In Stock
We'll send you an email when Switchcraft 188 1/4" Mono Plug Heavy Duty Nickel is back in stock or available for preorder.
Switchcraft's 1/4" mono plugs have one-piece tip rods for added strength and durability. Large curved tip solder terminal makes it easier to solder to heavy gauge wires. Longer sleeve terminal allows more room to make sleeve solder connections. Extra-large cable clamp securely grips cable of up to 0.450" in diameter. Will easily accommodate some varieties of four conductor 14 gauge wire and parallel two conductor 12 gauge wire. Bendable tab on sleeve terminal makes termination easier by holding down cable while soldering. In addition, such mechanical retention makes for a superior solder connection. Will handle up to 15A. Features include solder terminals and a shielded nickel handle. Mfg. #188.
BrandSwitchcraft
Model188
Part Number093-126
UPC844632071706
Weight0.1
ConductorsMono TS
GenderMale / Plug
Mounting TypeCable Mount
