  • Coax-Seal Moisture Proof Sealing Tape 1" x 12 ft. Pro Pack
Coax-SealPart # 180-210
Model: 106
Coax-Seal is a special material which will quickly and effectively seal all types of coaxial fittings of any shape from moisture, water and corrosion. Coax-Seal stays flexible for years thus insuring moisture proof connections. Four 12 ft. rolls per pack.
  • Seals electrical fittings from moisture and corrosion
  • Stays flexible at any temperature
  • Insures low SWR
  • Fast and easy seal for all antenna connections
  • Forms over odd shapes and sizes
Coax-Seal Moisture Proof Sealing Tape 1/2" x 12 ft. Pro Pack
Price: $26.98Part # 180-208
See all items in Self-fusing Tape
Your Price: $39.98
MSRP: $42.99
Save $3.01 (7%)
5 In Stock
We'll send you an email when Coax-Seal Moisture Proof Sealing Tape 1" x 12 ft. Pro Pack is back in stock or available for preorder.
Coax-Seal is a special material which will quickly and effectively seal all types of coaxial fittings of any shape from moisture, water and corrosion. Coax-Seal stays flexible for years thus insuring moisture proof connections. Insures good SWR and long coax life. Coax-Seal also allows you to disconnect and reconnect fittings with the same material by simply re-forming the plastic. Coax-Seal is the only material that will adhere to vinyl and poly vinyl connector outer covers. Coax-Seal is non-toxic, non-corrosive, non-conducting, and has hundreds of uses in electronics. 1" x 12 ft.\ Stays flexible at any temperature. Four 12 ft. rolls per pack.
BrandCoax-Seal
Model106
Part Number180-210
UPC857142000005
Weight3.75
