  • Celestion Rocket 50 12" 8 Ohm Guitar Speaker 50W
CelestionPart # 294-2300
Model: Rocket 50
Rocket 50 Specifications: • Nominal diameter: 12" (305 mm) • Power rating: 50 watts • Nominal impedance: 8 ohm • Sensitivity: 95 dB • Chassis type: Pressed steel • Voice coil diameter: 1.75" (44.5 mm) • Frequency range: 85-5,000 Hz • Fs: 90 Hz • DC resistance, Re: 6.74 ohm.
Celestion Midnight 60 12" 60W Guitar Speaker 8 Ohm
Price: $95.00Part # 294-1984
See all items in Guitar Speakers & Bass Guitar Speakers
Your Price: $72.50
MSRP: $108.75
Save $36.25 (33%)
Out of Stock
We'll send you an email when Celestion Rocket 50 12" 8 Ohm Guitar Speaker 50W is back in stock or available for preorder.
Look inside the back of a standard 4x12 and you may well find a quartet of Rocket 50s. The Rocket 50 by Celestion performs well with any playing style, and won't break the bank.
Overall Specifications: • Nominal diameter: 12" (305 mm) • Power rating: 50 watts • Nominal impedance: 8 ohm • Sensitivity: 95 dB • Chassis type: Pressed steel • VCdia: 1.75" (44.5 mm) • Voice coil material: Round copper • Magnet type: Ceramic • Frequency range: 85-5,000 Hz • Fs: 90 Hz • DC resistance, Re: 6.74 ohm.
Mounting Information: • Diameter: 12.2" (309 mm) • Overall depth: 4.8" (122 mm) • Magnet structure diameter: 3.9" (100 mm) • Cut-out diameter: 11.1" (283 mm) • Mounting slot dimensions: 0.31" (7.9 mm Ø) • Number of mounting slots: 4 • Mounting slot PCD: 11.7" (297 mm) • Weight: 4.4 lbs. (2 kg).
BrandCelestion
ModelRocket 50
Part Number294-2300
UPC739894560641
Weight5.15
Nominal Diameter12"
Power Handling (RMS)50 Watts
