  • Celestion Pulse12 12" 200W Bass Guitar Speaker 8 Ohm
CelestionPart # 294-2464
Model: Pulse12
Celestion designed the Pulse bass guitar speakers in response to the specific needs of today's bass players. Delivering incredible detail and definition, warm midrange response, and powerful low end. The Pulse 12 will provide reliable amplification in any situation.
  • Long throw design with 4 mm Xmax for powerful bass you can feel
  • 8 Ohm impedance provides an easy load to most amps, also ideal when using multiples
  • Reinforced steel frame keeps cost down without sacrificing reliability
  • 2" voice coil on a Polyimide former with adequate venting handles 200 watts
Your Price: $119.00
MSRP: $178.50
Save $59.50 (33%)
Only 1 In Stock More due on 1/30/2026
We'll send you an email when Celestion Pulse12 12" 200W Bass Guitar Speaker 8 Ohm is back in stock or available for preorder.
For bass players demanding well-defined clarity and stunning articulation together with a rich, full tone, PULSE 12 bass speaker deliver an ideal combination of responsiveness and rock solid low end. The Kevlar-loaded cone pulses with up to 200 watts of raw bass power. Expect each note to deliver a thick, percussive attack along with the mid-range necessary to break through in any performance situation.
Overall Specifications : • Nominal diameter: 12" • Power rating: 200 watts • Nominal impedance: 8 ohms • Sensitivity: 94 dB • Chassis type: Pressed steel • VCdia: 2" • Voice coil material: Copper • Magnet type: ferrite • Frequency range: 45-3,500 Hz • Fs: 45 Hz • DC resistance, Re: 5.88 ohms.
Mounting Information : • Diameter: 12.2" • Overall depth: 5.1" • Cut-out diameter: 11.1" • Number of mounting holes: 8 • Weight: 7 lbs.
BrandCelestion
ModelPulse12
Part Number294-2464
UPC739894596954
Weight9.1
Nominal Diameter12"
Power Handling (RMS)200 Watts
