  • Celestion CDX1-1446 1" 20 Watt Compression Driver 8 Ohm
CelestionPart # 294-2121
Model: CDX1-1446
Celestion's CDX1-1446 1" 8 ohm compression driver features a compact design with state of the art technology. The one-piece PETP diaphragm provides reliable and natural response needed for professional sound systems.
  • 1" exit with 1-3/8"-18 TPI mount for easy installation
  • 106 dB sensitivity and 20 watt power handling ensures high output
  • Durable design with a one piece PETP diaphragm and surround
  • Finite Element Analysis (FEA) techniques used to optimize both magnetic and acoustic components
  • Recommended 2,200 Hz 12 dB/octave crossover makes this driver suitable for both 2 way and 3 way designs
Your Price: $59.00
MSRP: $88.50
Save $29.50 (33%)
Only 2 In Stock
We'll send you an email when Celestion CDX1-1446 1" 20 Watt Compression Driver 8 Ohm is back in stock or available for preorder.
Order in the next 5 hr 43 min to ship today. Details
Celestion's compact and versatile CDX1-1446 1" high frequency driver with 1-3/8"-18 TPI mount is the result of the company's extensive experience, and its commitment to rigorous technical analysis. The driver's advanced non-metallic PETP diaphragm provides accurate, non-fatiguing response, while offering a higher level of durability than shatter-prone metallic domes. Celestion's new drivers are in great demand by popular loudspeaker system manufacturers, and after a single listen to the CDX-1446 it will be easy to understand why!
Specifications: • Power handling: 20 watts RMS with recommended crossover of 2,200 Hz, 12 dB/octave slope • VCdia: 1.4" • Impedance: 8 ohms • Frequency response: 1,500-20,000 Hz • SPL: 106 dB 1W/1m • Dimensions: 3.54" diameter x 2.71" depth • Net weight: 2.4 lbs. • Mounting: 1-3/8"-18 TPI • Replacement diaphragm: 294-2180
BrandCelestion
ModelCDX1-1446
Part Number294-2121
UPC739894579643
Weight2.5
Diaphragm MaterialPoly / Mylar
Exit Diameter1"
Mounting Type1-3/8"-18 TPI
Power Handling (RMS)20 Watts
