  • Eminence PXB:3K5 High Pass Crossover Board 3,500 Hz
Eminence SpeakerPart # 290-602
Model: PXB:3K5
Eminence PXB crossovers feature advanced circuit design to both preserve the crossover and your HF drivers.
  • Crossover type: High pass, board only
  • High pass frequency: 3,500 Hz, 18 dB/octave
  • Power handling: 400 watts RMS
Your Price: $55.99
MSRP: $69.99
Save $14.00 (20%)
6 In Stock
We'll send you an email when Eminence PXB:3K5 High Pass Crossover Board 3,500 Hz is back in stock or available for preorder.
Eminence PXB board-only crossovers are a lower cost alternative to the "cabinet ready" models and are targeted specifically for custom cabinet projects as they do not include the terminal cup, input connectors or L-pad found on the "cabinet ready" models. They feature advanced circuit design to both preserve the crossover and your drivers. A benefit of the design is to form a voltage divider across the high frequency driver. The high-pass protection uses custom-built aerospace lamps. The tungsten filaments effectively track the program material, dynamically maintaining a safe maximum current level to the high frequency driver without introducing distortion. This circuitry provides smooth 3:1 analog compression during input overload conditions over 250 watts RMS. At full drive level approaching clipping, the electrical attenuation to the protected high frequency driver is -4.5 dB. In every way, Eminence pxb crossovers are a technically superior product. For use with 8 ohm drivers.
BrandEminence Speaker
ModelPXB:3K5
Part Number290-602
UPC876358001538
Weight0.82
Crossover TypeHigh Pass
