  • Celestion CDX1-1412 Neo 1" Compression Driver 35W 16 Ohm
CelestionPart # 294-1964
Model: CDX1-1412
The CDX1-1412 is the latest of Celestion’s high frequency compression drivers, and features plenty of output for a driver this size:  35W (AES standard), 70W (Continuous) power rating, and 107dB sensitivity across a 1500 to 20kHz frequency band.
  • 16 ohm impedance
  • Very compact design for highly portable applications
  • 2,000Hz recommended minimum crossover frequency (12dB/oct)
  • Single piece polyimide film diaphragm and surround
Your Price: $85.00
MSRP: $127.50
Save $42.50 (33%)
We'll send you an email when Celestion CDX1-1412 Neo 1" Compression Driver 35W 16 Ohm is back in stock or available for preorder.
Designed and developed at Celestion’s headquarters in Ipswich, England, the CDX1-1412 features a 34mm/1.4 inch diameter edge-wound copper clad aluminum voice coil, and a 25mm/1 inch exit size. The new driver provides 70-watt power handling and delivers a 107dB sensitivity performance over a frequency range of 1,500-20,000Hz, with a recommended crossover frequency of 2,000Hz. The unit features a single piece Polyimide film diaphragm and surround, and is fabricated using a rigid engineering thermoplastic with a standard 2xM5 bolt fitting. Acoustic foam is utilized to minimize internal air cavity resonances, dampening unwanted reflections from the inside of the cover.
BrandCelestion
ModelCDX1-1412
Part Number294-1964
UPC739894648240
Weight0.85
Diaphragm MaterialPoly / Mylar
Exit Diameter1"
Mounting Type2-Bolt
Power Handling (RMS)35 Watts
Impedance16Ω
