  • Cat 6 UTP Ethernet Network Patch Cable 550 MHz 10 ft. Yellow
Parts ExpressPart # 150-425
1 Question, 1 Answer or
Improve your home or office network connection speeds using Category 6 Ethernet patch cables. Useful for connecting local area network (LAN) / wide area network (WAN) segments, hubs, switchers, routers, patch panels, and other unshielded twisted-pair (UTP) applications.
  • 4-pair 24 AWG stranded copper conductors with a PVC jacket for great performance in home and office networking applications
  • Supports a bandwidth up to 550 MHz for improved transfer speeds
  • Outperform Category 5e (Cat5e) cables
  • For use with LAN/WAN segments and other UTP applications
  • Molded strain relief with snagless design protects RJ45 connectors
Your Price: $3.49
MSRP: $8.99
Save $5.50 (61%)
6 In Stock
We'll send you an email when Cat 6 UTP Ethernet Network Patch Cable 550 MHz 10 ft. Yellow is back in stock or available for preorder.
Order in the next 11 hr 57 min to ship today. Details
Given the ability to be used with LAN/WAN segments, hubs, switches, routers, patch panels, and other UTP applications, Category 6 Ethernet patch cables provide a high transfer speed solution for your home or office network patching needs. The cable has a RJ45 connector on each end with molded strain relief for durability, and gold plated pins for improved connectivity. RoHS compliant.
Specifications: • Conductor: 4-pair 24 AWG stranded copper • Bandwidth: 550 MHz • Jacket: PVC • Exceeds Category 5e specifications.
Part Number150-425
UPC848864033495
Weight0.3
Cable Length10feet
Cable TypeCategory 6
Jacket ColorYellow
Special FeaturesMolded Strain Relief-Snagless
