  • Cat 6 UTP Ethernet Network Patch Cable 550 MHz 5 ft. Red
Parts ExpressPart # 150-416
1 Question, 2 Answers or
Improve your home or office network connection speeds using Category 6 Ethernet patch cables. Useful for connecting local area network (LAN) / wide area network (WAN) segments, hubs, switchers, routers, patch panels, and other unshielded twisted-pair (UTP) applications.
  • 4-pair 24 AWG stranded copper conductors with a PVC jacket for great performance in home and office networking applications
  • Supports a bandwidth up to 550 MHz for improved transfer speeds
  • Outperform Category 5e (Cat5e) cables
  • For use with LAN/WAN segments and other UTP applications
  • Molded strain relief with snagless design protects RJ45 connectors
Your Price: $1.98
MSRP: $2.99
Save $1.01 (34%)
We'll send you an email when Cat 6 UTP Ethernet Network Patch Cable 550 MHz 5 ft. Red is back in stock or available for preorder.
Estimated back in stock 7/25/2025
Given the ability to be used with LAN/WAN segments, hubs, switches, routers, patch panels, and other UTP applications, Category 6 Ethernet patch cables provide a high transfer speed solution for your home or office network patching needs. The cable has a RJ45 connector on each end with molded strain relief for durability, and gold plated pins for improved connectivity. RoHS compliant.
Specifications: • Conductor: 4-pair 24 AWG stranded copper • Bandwidth: 550 MHz • Jacket: PVC • Exceeds Category 5e specifications.
Part Number150-416
UPC848864033310
Weight0.15
Cable Length5feet
Cable TypeCategory 6
Jacket ColorRed
Special FeaturesMolded Strain Relief-Snagless
