  • Cat 6 550 MHz Plenum UTP Blue 1000 Ft.
Parts ExpressPart # 101-436
This high quality, fire retardant, 1,000 ft. blue CAT 6 cable is ideal for both residential and commercial use.
  • Solid bare copper 23 gauge 4 pair with CMP plenum Jacket for fire code
  • Tested up to 550 MHz
  • Complies with the ANSI/TIA/EIS-568-A testing
  • Meets UL 444 standards
  • RoHS compliant
Your Price: $359.98
MSRP: $530.99
Save $171.01 (32%)
4 In Stock
We'll send you an email when Cat 6 550 MHz Plenum UTP Blue 1000 Ft. is back in stock or available for preorder.
Solid plenum cable is normally used for permanent cable pulls in plenum areas, or duct work, where a fire retardant cable is required by code. Install with confidence, because it meets UL 444 standards.
Specifications: • Overall diameter: 0.276" • Jacket thickness: 0.024" • Insulation thickness: 0.010".
Part Number101-436
UPC848864039985
Weight31.15
Cable RatingCMP Plenum Rated
Cable TypeCategory 6
Jacket ColorBlue
Wire Gauge23
