  • CAIG DeoxIT D100L-25C Needle Dispenser 25 ml
CAIG LaboratoriesPart # 341-220
Model: D100L-25C
DeoxIT is a fast-acting deoxidizing solution that cleans, preserves, lubricates and improves conductivity on all metal connectors and contacts. Use as a general treatment for connectors, contacts and other metal surfaces, and on non-critical metal surfaces with severe oxidation and corrosion.
  • Improves conductivity and reduces itermittent connections
  • Helps dissolve corrosion and oxidation on metal surfaces
Your Price: $35.99
Save $6.96 (16%)
We'll send you an email when CAIG DeoxIT D100L-25C Needle Dispenser 25 ml is back in stock or available for preorder.
Expected back in stock any day
DeoxIT is a fast-acting deoxidizing solution that cleans, preserves, lubricates and improves conductivity on all metal connectors and contacts. Use as a general treatment for connectors, contacts and other metal surfaces, and on non-critical metal surfaces with severe oxidation and corrosion. If the metal surface is discolored, the corrosion is severe. DeoxIT dissolves the contamination and protects the surface. Not only does DeoxIT remove corrosion but it also seals and protects all electrical connections, and reduces intermittent failures, arcing, wear, and abrasion. Temperature range: -34°C to 200°C. 25 mL, 100% DeoxIT liquid. Includes needle type dispenser. Non-flammable, non-toxic.
BrandCAIG Laboratories
ModelD100L-25C
Part Number341-220
UPC697429002052
Weight0.17
