  • Bluetooth APP Controlled Low Voltage Lighting Power Switch 5-28 VDC 8 Amp
CLEARANCE Bluetooth APP Controlled Low Voltage Lighting Power Switch 5-28 VDC 8 Amp
Parts ExpressPart # 073-095
Universal APP controlled power switch great for any low current applications including LED light strips. Turn anything off/on, dim LED lights or motors, and respond to music with your smartphone. The Bluetooth controller works with LED light strips that require 5 to 28 VDC.
  • Wide 5 to 28 VDC working range for versatility
  • Accepts common 2.1 x 5.5 mm tip positive DC coax style connectors
  • Make LED lights turn on/off, dim, and respond to music with the Free Hao Deng app for your smartphone
CLEARANCE $4.28
Save $20.51 (83%)
14 In Stock
We'll send you an email when Bluetooth APP Controlled Low Voltage Lighting Power Switch 5-28 VDC 8 Amp is back in stock or available for preorder.
Order in the next 1 hr 41 min to ship today. Details
Wirelessly control with a free smartphone app 5 to 28 VDC single color LED lights and more with this Bluetooth controller. Turn them on and off, dim, or make lights respond to music. Simply insert the controller between your power cord and LED lights that have a 2.1 x 5.5 mm DC coax connector. The controller handles up to 8A of current for long LED strips and also turns on/off other 5 to 28 VDC devices right from your smartphone.
Part Number073-095
UPC848864067483
Weight0.06
