  • 12V DC 3A AC Adapter Power Supply with 2.1 x 5.5mm Center Positive Tip with Polarized AC Cord
BUYOUT 12V DC 3A AC Adapter Power Supply with 2.1 x 5.5mm Center Positive Tip with Polarized AC Cord
Factory BuyoutsPart # 129-1204
Model: EPS-3
This adapter buyout replaces many 12 VDC adapters for around half the cost of other 3,000mA power supplies. Its tip positive 2.1 x 5.5 mm plug is the most common size for portable amplified speakers, cable boxes, and LED light strips.
  • Long 6 ft. DC cord for flexibility
  • 5 ft. polarized input AC cord for added safety
  • Level VI compliant for energy efficiency
  • 12 VDC 3A for small amp boards and LED light strips
  • UL approved for safety
  • Switching power supply delivers constant voltage
BUYOUT $6.97
Save $8.02 (54%)
552 In Stock
We'll send you an email when 12V DC 3A AC Adapter Power Supply with 2.1 x 5.5mm Center Positive Tip with Polarized AC Cord is back in stock or available for preorder.
12 VDV 3A power adapters are in high demand for audio amp boards, musical keyboards, portable powered speakers, and LED light strips. Its popular 2.1 x 5.5 mm tip positive plug fits most 12 VDC electronic devices without having to change or adapt the plug. The 12 VDV 3A output current fills the power needs for many 50 watt audio projects. This is a factory buyout, so quantities are limited.
Specifications: • Input voltage: 100-120 VAC • Input current: 1.2A • Output Voltage: 12 VDC • Current output: 3A • Power range: 36 watts • Output cord: 6 ft. with 2.1 x 5.5 x 10mm center positive plug • Input cord: Polarized 5 ft. • Dimensions: 5-1/4" L x 2-1/4" W x 1-5/16" H.
BrandFactory Buyouts
ModelEPS-3
Part Number129-1204
UPC848864068152
Weight0.85
Center/Tip PolarityCenter Positive
Current Capacity3000mA
DC Output Voltage12V
Input Voltage120 VAC
Plug Size2.1 x 5.5 mm
