NEW Beyma CD-2514Fe/PK 1.4" Polymer Diaphragm Compression Driver 8 Ohm 4-Bolt
The Beyma CD-2514Fe/PK is a next-generation 1.4" (36 mm) exit compression driver designed for professional audio systems requiring high power handling, extended frequency response, and low distortion.
- 2.5" (63.5 mm) copper-clad aluminum voice coil with Nomex former enhances durability
- High-temperature polymer dome and surround design optimized with F.E.M. for linear, extended response with minimized resonances
- Incorporates Deplocex patent-pending technology for improved thermal dissipation and reduced power compression
- Copper shorting cap reduces distortion, linearizes inductance, and increases output
- Proprietary metal alloy phase plug with F.E.M.-optimized geometry for improved performance
- F.E.M.-optimized ceramic magnetic circuit enhances efficiency
- Aluminum cover provides structural integrity
We'll send you an email when Beyma CD-2514Fe/PK 1.4" Polymer Diaphragm Compression Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
