  • Behringer S32 32 x 16 Digital Snake with AES50 Port Ultranet & Powerplay P16 Integration
CLEARANCE Behringer S32 32 x 16 Digital Snake with AES50 Port Ultranet & Powerplay P16 Integration
Behringer
Part #248-6953
Behringer
Part #248-6953
Model: S32
Digital mixing has revolutionized virtually everything in the live-entertainment production workflow. Now Behringer has come up with the perfect solution for connecting the onstage talent with your Front of House (FOH) console, and the rest of the world: the ultra-cool and ultra-affordable S32 Stage Box!
  • 32 MIDAS-designed, fully programmable mic preamps for audiophile sound quality
  • 16 analog, servo-balanced XLR outputs
  • AES50 network ports featuring Klark Teknik’s SuperMAC networking capability for ultra-low jitter and latency
  • ULTRANET distribution hub for powered connection of a P16-M personal monitoring mixer
  • Digital audio and control connectivity for TURBOSOUND speaker systems with ULTRANET networking capability
The S32 provides 32 MIDAS-designed remote-controllable mic preamps, 16 balanced analog XLR returns at the stage end, plus an integrated ULTRANET distribution hub for direct connection to Behringer's P16-M personal monitor mixer - without any additional hardware required.
Plus the S32 is extremely compact and built to withstand the rigors of road life, and only occupies 3 rack spaces. The best part – all it takes is a single shielded CAT5e cable per stage box (up to 330 ft / 100 m length). And If you need more inputs, or just want to keep your cable runs short and tidy, the S32 can be linked with an SD16 or S16, so you're covered there, too.
When used as part of a complete X32 system, two S32 Stage Boxes can be connected via the built-in AES50 ports to provide up to 64 balanced XLR Combo inputs and 32 balanced XLR outputs. An onboard ULTRANET distribution hub provides power and 16 channels of audio to one Powerplay P16-M personal monitor mixer per S32, all via inexpensive shielded CAT5e cabling, and without any additional hardware. As if all that weren't enough, the S32 also gives you MIDI in/out, two TOSLINK optical ADAT outputs, and two AES/EBU digital connectors as well.
BrandBehringer
ModelS32
Part Number248-6953
UPC748252156648
Weight14.6
