Banana Spring Connector Two Pair, Two Black Two Red
The Banana Spring Connector Two Pair offers a straightforward way to connect speaker wire to audio equipment. Designed with dual set screws and a spring-loaded rib in the connector, these connectors will stay secure for all your needs.
- Accepts up to 8 AWG wire
- Spring-loaded rib in connector provides extra secure fit
- Two steel set screws provide an extra tight hold on the wire
- No crimping or soldering required
- Gold-plated brass construction
We'll send you an email when Banana Spring Connector Two Pair, Two Black Two Red is back in stock or available for preorder.
