  • BWS265P 2 Wire SPST 6A 125 VAC Toggle Switch with Leads and Plug
CLEARANCE BWS265P 2 Wire SPST 6A 125 VAC Toggle Switch with Leads and Plug
Factory BuyoutsPart # 299-562
Model: BWS265P
Save time trying to solder or crimping connectors to terminals with this prewired mini SPST toggle switch.
  • 25" leads with plug for quick installation and flexibility
  • Includes on/off plate for external contact status
We'll send you an email when BWS265P 2 Wire SPST 6A 125 VAC Toggle Switch with Leads and Plug is back in stock or available for preorder.
Soldering or crimping connectors to small switch terminals is time consuming. This prewired SPST switch saves you from that headache and the 25" lead wire with plug (if needed) gives you plenty of flexibility. The 6A 125 VAC rating enables you to use it many projects without having to make a large mounting hole. It mounts in a 0.25" hole and has a long 0.31" threaded shaft. The switches body dimensions are 0.52" W x 0.37" H x 0.32" D and the stem sticks out 0.4". Mount the switch with two shaft nuts, and star washer included.
BrandFactory Buyouts
ModelBWS265P
Part Number299-562
UPC848864062082
CircuitSPST
Contact Rating @ Voltage6A 125 VAC
IlluminationNon-Illuminated
